Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
ConnAPI.DLL how do I re-install?
Is this problem connected to the Abode program and how do I get it to re-install?
    Sniper:
  • 96 Answers
Open web page http://www.dll-files.com/dllindex/dll-files.shtml?connapi
Download the file. Remember location to save. Reinstall the Roxio software. When installation prompts for ConnAPI.dll file, show the path. Use the same procedure for the other dll files if necessary Search and download these files at http://www.dll-files.com/
Posted on Jan 25, 2009
I'm running Windows Vista and PC Suite version 7.0.8.2 fails to open up due to the following message: 'This application has failed to start because ConAPI.DLL was not found. Reinstalling the application...
Hi there...
I had a similar problem with .DLL error messages. This is typically something going in the start up menu system of your computer. I used a program called RegCurePro and is very simple to install and run. Once it completes its first scan, find the "ConAPI.DLL" in the list, right click and delete it. Should be fine from there on out....
Nov 28, 2013 | Computers & Internet
Ie shows error message(, ModName ntdll.dll.) then shuts down when I use USB storage drive. I have removed Internet explorer but still shows the error message and shuts down
The causes of ntdll.dll error messages can vary greatly. However, most ntdll.dll errors result from a corrupt or damaged version of the ntdll.dll file itself, corrupt hardware drivers, or issues between Windows and other programs.
Ntdll.dll errors can sometimes mean that a piece of hardware in your computer is malfunctioning, but this is rare.
Resolution
1.Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
2.Reinstall the program if the ntdll.dll error only displays when you use a specific program.
If the software program has any updates or service packs available, install them too. The software's programmers may have identified an issue with the program that caused the ntdll.dll error and then issued a patch for it.
Note: Third party software programs that have been installed on your computer are almost always the cause of ntdll.dll errors. The remainder of these troubleshooting steps resolve ntdll.dll issues only rarely.
3.Check the Windows service pack level you're running and then check Microsoft's support site to see if there is a more recent service pack available for installation. Some issues that caused ntdll.dll errors have been corrected in these service packs from Microsoft.
4.Selectively disable Internet Explorer add-ons. If your ntdll.dll error is displaying when you start, run, or close Internet Explorer, an add-on may be causing the problem. Disabling each add-on, one by one, will determine which add-on is the culprit (if any).
Note: As a workaround, assuming the ntdll.dll error really is Internet Explorer related, install and use a competing browser like Firefox.
5.Rename the NLSPATH system variable. If your Windows system does not have this environment variable, skip this step.
Note: This is a troubleshooting step for this issue only. Be sure to set this path back to its original name if this does not resolve the ntdll.dll issue.
6.Disable Data Execution Prevention for Explorer.exe. As in the previous step, this is for troubleshooting the ntdll.dll issue only. If this doesn't resolve the problem, return the Data Execution Prevention settings to their previous settings.
7.Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
8.Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Replace your memory if it fails any of your tests.
9.Ntdll.dll errors could occur if you have an Iomega Zip drive on the same IDE cable as the hard drive inside your computer. If so, move the Zip drive to a dedicated IDE controller.
10.Replace the IDE cable connecting the hard drive to the motherboard. If this cable is damaged or malfunctioning, one symptom could be the ntdll.dll error you're seeing.
11.Repair your installation of Windows. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file.
12.Perform a clean installation of Windows. A clean installation will completely remove Windows from your PC and install it again from scratch. I don't recommend this option unless you've exhausted all previous troubleshooting ideas and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2).
Note: If a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
13.While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive.
If so, replace the hard drive and then perform a new installation of Windows.
Jul 20, 2011 | Microsoft Internet Explorer 8
Trying to install Lexmark X1150 on my XP computer and getting messages that it requires lxbkcfg.dll and lxbkdr5c.dll.
First, unplug the printer from your computer.
Then uninstall any programs for it from Add/Remove Programs in the Control Panel.
Go to Lexmark's website and find the support section.
Look for drivers and downloads for your printer.
Select the Windows XP driver, download it and install it.
Only connect your printer when the installation prompts you to connect it or when the install has completed.
Good luck! If this helps please vote for my solution.
Oct 12, 2010 | Lexmark X1150 All-In-One InkJet Printer
Uninstall Abode Reader 9.1 before?
I assume you are having issues with Adobe Reader and want to start over. Yes, uninstall the program first and then reinstall.
  1. Exit from all applications.
  2. Uninstall Acrobat.
  3. Search for and delete any .tmp files on your computer.
    1. Delete the following items, if present, from the Documents and Settings/[user profile]/Local Settings/Temp folder:
    2. Folders:
      • _istmp[x].dir
    • Files:
      • _ins[x]._mp
      • _inst32i.ex_
      • _inz[x]._mp
      • _isdel.exe
      • _istmp[x].dir
      • _setup.dll
      • _setup.lib
      • _wutl[x].dll
      • ~ins[x].~mp
        where "[x]" is any number
  • Then reinstall the new Reader program.
    Jan 30, 2010 | Microsoft Internet Explorer 8
    D3drm.dll promblem
    Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
    Nov 07, 2009 | Microsoft Windows Vista Ultimate Edition
    Userpmd.dll Error code:998-Invalid Access to memory
    I bet you have installed Client Access V5R1 with an servicepack.
    I had the same problem ...
    Try installing it without a servicepack and it will work. If you need the ODBC connection just overwirte the unpatched dll with the dll from the patched version.
    good luck
    Gregor
    Sep 11, 2009 | IBM Computers & Internet
    On trying to launch Quattro PRO for idows (Vers 5) it comes up with the message "Can not find LD01.DLL"
    Search for the file on the system. If it cannot be found, you will need to reinstall Quattro Pro. If the file is there, post back here with your operating system and I'll let you know how to re-register the DLL with the system. (The commands differ depending on the OS you are running.)
    Jul 11, 2009 | Borland Quattro Pro 5.0
    I want to uninstall adobe reader 8
    hai! click START menu->ALL PROGRAMS->click the abode reader8->click the uninstall
    (otherwise)
    Goto->START->CONTROL PANEL->ADD OR REMOVE PROGRAM->you can see the abode reader 8 JUST single click and CLICK REMOVE! After that you can install whenever you want!
    Sep 15, 2008 | Computers & Internet
    Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
    1,164 people viewed this question
    Top Roxio Computers & Internet Experts
    Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
