Question about Pentax Optio 33L Digital Camera
Stuck between opened and closed
Problems with our Pentax Optio 33L. We first noted the problem when we had finished downloading images onto our computer, then very quickly scrolled up the images. At that point, a message popped up onto the computer saying that the camera had been shut off incorrectly and data might be lost. The camera icon had disappeared from the computer desktop. We unplugged the camera from the computer and tried to shut it off. It did not respond. The small red "flash indicator" light stayed lit and would not turn off. We took the batteries out and left the camera overnight. Next morning we put the batteries back in and tried to turn it on. The lens came part way out and stopped. Now we can't turn it on or off. It is not recognized by the computer if we try to download. We have tried fresh batteries, fresh memory card, plugged it in to the wall, plugged it into the computer. Is there a reset button, or something to clear it? It seems just locked up. Thank you!
    Genius:
  • 2,985 Answers
Have tried twisting it around to see if gravity has any affect? Looks like a warranty job is it still has one. If not, get a quote from one of the repair firms, but I suspect the likely cost of any repair if at all possible will be very near a replacement.
Posted on May 08, 2007
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Pentax Optio S10 Digital Camera
I NEED TO DOWNLOAD DRIVERS FOR A PENTAX OPTIO 33L SO IT WILL WORK WITH WINDOWS 7 ON MY NEW COMPUTER. I CAN NOT LOCATE A FREE DOWNLOAD. THIS IS A GOOD CAMERA BUT IT IS NOT COMPATABLE WITH WINDOWS 7.
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 12, 2010 | Pentax Optio 33L Digital Camera
Where can I purchase the USB cable for the pentax optio 33L?
Replacement cables can be purchased at stores like Walmart, Bestbuy, etc. Take your camera with you to get the correct size plug into your camera.
Nov 09, 2010 | Pentax Optio 33L Digital Camera
Lost disc for pentax optio 33L digital camera unable to load photos
Consider NOT using a driver to connect your camera to your computer.,
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 28, 2010 | Pentax Optio 33L Digital Camera
Windows vista not compatible with pentax optio 33l
If you're using an sd card or most other standard memory cards you can buy a card reader very cheaply and plug it into the usb of your computer, your computer may even have a reader built in
Sep 03, 2009 | Pentax Optio 33L Digital Camera
Windows Vista Compatability
You do not need any form of driverThe computer simply reads the camera as another removable drive
It will inact show the Camera/Scanner Wizard
Jun 10, 2008 | Pentax Optio 33L Digital Camera
New computer does not recognize pentax 33l
Optio 33L and Vista
Plug camera into USB port using the cable supplied, and switch the camera on. Computer will display the "found new hardware" sign, and ask you to insert the disk that came with the 33L into the disk drive. That done, the drivers will be installed in the usual manner. AT LEAST, THAT'S HOW I DID IT - AND IT WORKS!
de VK5QV
Feb 18, 2008 | Pentax Optio 33L Digital Camera
Lost Cd
Actually, if you're using XP you should not need the disc at all to shoot & download images. If you're looking for software so you can crop & that sort of thing, I recommend googles Picasa program, its free. To download images without the disc simply connect the camera like you have in the past and XP will find the device & walk you thru downloading images, usually. If not, click on "my computer" and you should find your camera/device listed there. Personally, I use a card reader and take my memory card out and download the images using the reader.
Jun 23, 2007 | Pentax Optio 33L Digital Camera
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Pentax Optio 33L Digital Camera Logo
44 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
