Question about Indesit W 123 Front Load Washer
Diplomat apm8703 heater element gone
I have located the heater, undone the nut which i assume holds it in place but cannot seem to remove it, i dont want to apply too much pressure for fear of damaging the drum, any idea's ? many thanks
  • 2 more comments
  • neil_cheryle Jan 01, 2009
    thankyou, there are two nuts, one which holds a bracket to the back of the machine, one which just tightens onto the heater element, do i remove both ? alos is the seal re-usable or will one come with the new element ? many thanks
    thanks again, last question, will the machine wash cold or will it stick on programs waiting for the water to heat
    many thanks
  • joey1542 Apr 26, 2009
    how to remove the heater element on a indesit wie 167
  • Indesit Master
  • 3,463 Answers
The nut should taken off completely, and then lever the heater out with a broad blade screwdriver or similar, u need to get behind the metal plate that holds the heater in, or get a good pair of grips and grip the metal plate of the heater, and pull it towards u,it can take some doing as the rubber seal will have expanded, and that is what is holding it in
Plz rate my solution and feel free to leave a comment.
Thanks.
Posted on Jan 01, 2009
  • Barry Coates
    Barry Coates Jan 01, 2009
    The new element will come with seal, certainly remove center nut altogether, as this is the one that usually compresses the seal.
    Only remove the other one if it seems to be holding the heater to the washer..
    Many thanks for your rating.
  • Barry Coates
    It depends on the way the washer timer is programmed, some will wash in cold water, others will sit and wait for the water to heat up, if this is the case, then just advance the timer onto the next stage of the wash, or if it has a seperate heater control, set it to min, and it should wash ,but only in cold water.;;
    If it is hot and cold fill ,select a hot fill prog and it will utilise your hot water.
How to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Sep 26, 2012 | Miele WT945 Front Load Washer / Dryer
Hoover washing machine Mod OPH 714D Error E16 in most programmes what dose it mean!
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Jun 30, 2011 | Hoover Washing Machines
I have a hotpoint aquarrius WMA 32 My element has gone how do I remove the old one?
Remove lower rear cover of washer, you will see the heater with 2 wires attached to it, and a thing that is called the thermistot, remove 2 heater wires, and loosen center securing nut, prize old heater out with a screwdriver or similar, fit new element and thermistor, reconnect and make sure it is tightened up securely.
Please rate my solution.
Thanks.
Jul 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Blows main fuse under load when going to spin
Sounds like it's scraping against your heater element.Remove back panel then remove heater element(two prongs with nut in centre)you will be able to see signs of damage if so that will have to be replaced. £20 - £30.00p. Your either overloading your machine or your bearings are have gone, to check bearings pull inner drum while holding outer drum if get movement and knocking they will also need replacing.
May 19, 2009 | LG Washing Machines
Change heater element on a Hotpoint Ultima WMA66P
I am assuming you have accessed the element, in the centre of the element is a fixing nut, remove this altogether, and lever element out with a broad blade screwdriver or similar.
Pull the thermistor out of the element, and transfer to new element.
Also transfer stainless steel fixing bracket to new element if there is one fitted. Refit new element
Plz rate my solution.
Thamks.
Jan 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Zanussi FJD1666W heater removal.
There is no easy way to access the heater without stripping it down.
Remove top cover.
Remove 2 scews at rear bottom of cabinet.
Remove 2 plastic covers at front bottom sides of cabinet, and remove 2 screws located in holes, you will need a nut socket to remove them.
Remove inlet hoses, and undo screw at top where the hoses connect to, prize up the plastic retainer that holds the valves in place.
Remove screws at top of cabinet that hold the 2 halves together.
Then lift rear half of cabinet clear of the front.
At the bottom rear you will see the heater element located.
Undo center nut and remove element..
Fit back all parts in reverse order.
Not an easy job. Good luck.
Thanks.
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Diplomat apd8703 filling problems
If I were u, I wud check the hose or chamber where the water level switch hose is terminated for any blockage or obstruction there as this is often the cause of the prob, u were certainly on the right track.
Plz rate my solution, and feel free to leave a comment.
Thanks.
Jan 01, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 heater element
no need to take drum out. heater is held by one 10mm nut in the middle of the heater. when tightened, this nut compresses the rubber seal and holds heater in place. loosen the nut. the heater will probably be too tight to remove by hand so carefully use a screwdriver to lever it out
Jun 26, 2008 | Indesit W 123 Front Load Washer
Heater element
there should be 1 nut that holds it in. undo this fully and the element has to be carefully prised out. replacement is in reverse, ensuring that the rubber seal is pushed fully home.
Feb 15, 2008 | Hotpoint WMA64 Front Load Washer
Indesit W 123 Front Load Washer Logo
70 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
