Question about Matsonic MS9087C Motherboard
Matsonic ms9087c boot hang and beeps
Hello, i recently unstalled a new graphics card on my matsonic ms9087c board. now when i boot up the comp freezes and just keeps beeping. i shut it down and put back in the old graphics card and it does the same thing just beeps. i tried to reseat both cards, took out the ram sticks and moved them and set them back in, but the comp will not boot. i know it has to be an easy fix but i am now at my wits end with it! Help
  • atfigure Jan 01, 2009
    i found this post on the net and it fixed my problem right up, just to be sure i did the jumper setting thing for both graphics cards and it worked
    by Methious ยป Fri Nov 23, 2007 6:56 pm
    This is kinda standard stuff you might have tried it already. Open the case, find JP1 it's a capped jumper with 3 pins, 2 are covered with a cap (this is cmos reset), it's usually the pin closest to the battery. Most times the cap on the pin is going to be the only one of a different color (white, red, blue) move the pin from pins 1 + 2 to 2 +3 for like 30 seconds (to reset cmos/bios). Move it back to pins 1 + 2 and try to start the machine. If that's a little to fuzzy to understand, unplug the power supply, remove the coin battery for like a minute (starves cmos/bios of the power it needs to maintain it's memory, same as jumping JP1 from 1/2 to 2/3) then replace the battery and try for a boot.
    Failing that try a different power supply.
    Failing that try unplugging every thing on the board one item at a time and replugging it, then try for a boot.
    Failing that go find a guy with a pocket protector or store it in the garage for parts.
    Good luck with it.
    Problem Solver:
Try re-setting the bios jumper, it's by the battery.
Posted on Jan 02, 2009
When I tern on my comp it is 3 beep what a problem
The Problem With RAM, If 3 short beeps( AMI bios). Video Problem Display Problem if One long beep and 2 Short beets( Award bios)
Remove the Power Connector from PC, and Open the cabinet and Locate the RAM, Remove it and put it back to same or diffent socket, or Try with New RAM.
if still no Use then it is the Display Problem, If display adapter is Onboard then motherboard needs Repair(Chip Level). try with new Graphics card. If you have any Graphics Card earliar then Try with New one. best of luck
Feb 03, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have an MS9158E Mainboard. this computer has been a real workhorse. Today, it did not post on the monitor. Change monitor did not help. Did not post on network either. Do I need a new mother board? or is...
Remove the Power connection. Open the CPU Cabinet, Locate The RAM, remove the RAM by Sliding both Clips, Insert it Back to same Slot or another. Try to boot it again, if still same problem then, Change the Graphics Card with New one. If still have the problem then only Replace the Motherboard. Best of luck
Feb 03, 2011 | Matsonic MS9158E+ Motherboard
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
My comp wont boot up
Try reinstalling the OS, I hope this will resolve this issue.
Aug 02, 2009 | Computers & Internet
8 continous beep
Put down or pull some your video card. On these motherboards this error mean a problem with your video card and sometimes it makes shorting. Or try to change your video card to another with pci slot
Mar 21, 2009 | Matsonic MS9087C Motherboard
Same problem
sata drivers are incorreact or corruted uninstall and reinstall new from msi web site.http://www.msicomputer.com/product/p_search.aspRICHARDM69
Dec 30, 2008 | Matsonic MS9087C Motherboard
MATSONIC
Try driverdownload.com or check manufactures website if possible.
Oct 09, 2008 | Matsonic MS9087C Motherboard
MS8308EP MANUAL
http://www.matsonic.com/drivers/view.php?modelID=MS8308EP
Jan 29, 2008 | Matsonic MS9158E+ Motherboard
Board power
Do you have any components compatable with the broken motherboard spare or in another desktop? try booting the motherboard with just a power supply, monitor, RAM and CPU. You may also need a video card if your motherboard does not have an integrated one.
If it shows no signs of life with other components that are know to work connected to it, then its a fair bet its dead.
Most hardware fault diagnosis especially with desktops is just a proccess of elimination.
Let me know if you have any luck chashole.
Jan 21, 2008 | Matsonic MS9087C Motherboard
No Power
Memory.
Suggest you cut down on the memory to using one DIMM.
Try your dimm down through the slots, one slot at a time. If still trouble, switch dimm and do the same. One beep is a memory issue.
Jan 13, 2008 | Matsonic MS9087C Motherboard
Matsonic MS9087C Motherboard Logo
184 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
