Question about LG WM-2077C Front Load Washer
I have a top load Kenmore washer, it is not spinning out and the drum is moving back and forth,
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
This is a bad motor position sensor. Since the machine cannot tell what position the motor is in it just spins back and forth trying to figure it out. Often an error code will pop up after 15-20 minutes.
A technician should be able to replace this part relatively cheaply. Hope this helps, please rate my solution.
Posted on Jan 11, 2009
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool duet banging on spin
with the door open,take your hands at 3 and 9 o'clock in the drum and try to move it back and forth,then try 12 and 6 o'clock try moving up and down if you can move it either way,the spider that holds the drum is broken behind the drum and needs replacing
Apr 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Top load washer works fine except from time to time it won't spin and discharge the rinse water thoroughly. Sometimes if I move the drum back and forth while manually spinning it, it will...
The first thing I would check would be the motor coupling, sounds like this is worn on your unit, you shouldnt be able to spin the basket by hand very easily. The couling could be engaing and then slipping. When the tub doesn't spin the water will not be pumped out. If it is making any grinding noise or whirring noise then that would point to the coupling. The coupling is only around $25.00 to buy and then a service call to get it replaced. Also check the lid switch to make sure it is working, if this switch does not make, the machine will not spin, this is a safety devise. You can push down on it with a pen or small scredriver and see if this is making and the drum spins while the lid is open. Sometimes when the coupling goes bad you might also get a slight burning rubber smell and this is an indicator that it is almost gone.
Nov 17, 2010 | Kenmore 22422 Top Load Washer
Washer is not rotating fully during wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Drum in kenmore top loaded washer is moving freely, loud in spin
YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
May 03, 2009 | Kenmore 24632 Top Load Washer
Kenmore 80 series washer
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
LG WM-2077C Front Load Washer Logo
52 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
