Question about Lexmark X1150 All-In-One InkJet Printer
Deleting - Printed
After printing a job, the print indicator window only goes to 99% and the job never completes itself, although the paper spits out and it is finished. If I try to then print another job, it won't print because it thinks the first job isn't done (but it is). When I try to open the queue, the first document says "Deleting- printed". It's almost like it's stuck at deleting the old job. The only way I can print another document is to turn the printer off and on again, then it resets itself to "idle". This can become quite annoying if I need to print multiple documents, as I have to turn the printer on and off between each job. What can I do?
  • 2 more comments
  • Anonymous Jan 09, 2008
    Same problem on a Lexmark X1270
  • lexmark1100 Apr 03, 2008
    Same problem with X1100 after upgrading from XP to XP pro.
    Will try winprint solution and see what happens.
  • Anonymous Nov 26, 2008
    same story - Dell 920 - post Window updates :(
  • Anonymous Mar 19, 2014
    delete job in print que
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
Posted on May 15, 2007
GregoryW's solution worked on a Dell AIO A940, except when I deleted the existing print spool files, the printers disappeared from the Printers and Faxes folder. I had to undelete one of them then the rest of the solution seems to have worked.
Posted on May 25, 2007
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
When I replace an ink module a message comes-up "new ink module installed". I am asked to align the print head. When I do this the printer doesn't accept it when I indicate "Yes". I perform the required...
first you complete the align test and for deleting the pending job you can do ,
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark x1240 printer will not print.
Keep your paper feed under 15 pages. The paper will tend to pull to the right, but it will print correctly on the printed page. 20 to 25 pages in the feeder will result in a paper jam. To find the status on the print job, go to your control conter and hit printers. Choose your spicific printer and you may beable to save the printjob.
Apr 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Status Box Remains at 99%
Try uninstalling then re-installing the drivers. Also if you are using Windows Vista you may need to go to the printer manufacturers website and download Vista drivers if you are running XP drivers for the printer.
Nov 24, 2007 | IBM Lexmark Z715 InkJet Printer
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Lexmark X1150 All-In-One InkJet Printer Logo
5,649 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
