Question about Toshiba Satellite A105 Notebook
Toshiba laptop frozen on home screen.
Hello. I have a toshiba satellite a105 that will boot upand gets stuck on homescreen. From this screen I cant access any program files the cursor is stuck. What do I do. Computer has been on for long time so its not a delayed issues.
  • ravinder Kumar
    ravinder Kumar May 11, 2010
    did you installed any program or changed any setting after which this problem persisting?have you tried to start the system with safe mode?is the whole system get freezed? or u able to use function through keyboard.
hmm I don't really understand what you mean by home screen ..but I think you mean the desktop ...and in this case ..If it freezes it means it is already corrupted. by a virus..and need to be reinstalled.This can be done using the recovery partition .or disk ..or using a boot-able disk with the operation system ..
If you have the recovery partition ..just start again ..and press f12 for the boot menu ..(or F11 depending on how is set ..and it is written on screen what you should press for this menu ) ..and select in the boot menu the recovery partition and the complete reinstalling of the operation system ..This will make it work again ..
Another thing that may caused this ..is if you installed more than one antivirus ..and now they ar ein conflict ...try to see if it works to make any commands if you wait...(if it is just really slow .) ..and if it works ..try to remove one ..if it is the case..and it may work and not need to reinstall it ..but ..in those cases usually the radical solution is the fastest and best ..
If you do not have a recovery disk or partition ..you need to borrow a operation system disk ..or make one by burning a downloaded image with the OS ..
They are available on the net ..if you are willing to try one ..(look on the torrent site ..like pirate bay or mininova ...and see what is available ...be sure you download a genuine one ..and follow the instructions for to burn it right and be functional ) ..
Oct 27, 2011 | Toshiba Satellite A105 Notebook
Okey i have a toshiba satellite a105 s2071. it was given to me but the person doesnt have the recovery disk and i tried so many ways to factory recover my notebook and nothing works what can i do????
hello. can you explain exactly what is happening.
Does the bios boot up? Does the operating system start assuming windows xp? Are you looking to recover previous work or a fresh install?
Jun 16, 2011 | Toshiba Sattelite A105-S2071 Notebook
Bios password shows on screen cant boot laptop
You can get it removed for FREE:
For Toshiba America we have this support bulletin - Incorrect power-on password prompt -- with older BIOS versions
To locate a Toshiba Authorized Service Center - http://pcrepair.toshiba.com/
And if you need assistance beyond this, call Toshiba at 800-457-7777
May 22, 2010 | Toshiba Satellite A105-S4034 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Mouse frozen on Laptop
try holding down Alt and press either F5 or F7
keep us informed please
regards
Dec 22, 2008 | Toshiba Satellite A105 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Spacebar stuck
you need a new keyboard most likely, contact your maker of your laptop and give them the information. you can also search up your make and model of your laptop on ebay and try to find a new keyboard that way. im 95% sure its the keyboard the rest could be software. if you have any more questions or comments pleasse email me at meanness628@aim.com
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite A105-S361
the inverter maybe going bad. go to ebay get a cheap toshiba satellite a105 lcd inverter.bam the problem fix oh you would need a screw drivercause this is a diy project no need tosend it out link me if anything bakerandre2000@yahoo.com
Apr 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
643 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
