Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
One or two of my cloth gets stuck and gets torn during washing
The cloth gets stuck somewhere during washing and gets torn or burnt like after being removed from the machine
  • 640 Answers
Slowly run your hand across the baffles ,,slowly or look with a flash light ,,1 of the may have came lose from drum...onthejob
Posted on Jan 30, 2009
Clothes getting burnt & torn in maytag front loading washer...how to resolve this issue asap?
Check the inside of the drum. Chances are, there is a sharp object pointing out that is doing this.
Jan 13, 2014 | Maytag EPIC MFW9700S Front Load Washer
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Sears 90 Series Washing Machined throws ground fault during spin.
pvatki, I am a licensed electrician and the NEC (national electrical code) does not require a clothes washer to be on a ground fault circuit interrupter. Replacing your gfci with a standard duplex receptacle will fix the problem you are having.
Dec 29, 2008 | Kenmore 15864/15862 Top Load Washer
Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Dec 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
