Question about Hitachi Performa CP-RS55 Multimedia Projector
CPRS55 starts flicker on 1024 *768 pixels
When i connect CPRS55 LCD Multimedia projector with duo core2 on 1024 * 768 pixels it gives flickering contineously in intervals and on 800*600 it completly keeps flickering. how do i set it. please reply.
I connect my quad core through the VGA, are you using the VGA socket?
Posted on Jan 13, 2009
My acer projector flickers after 10 minutes and very hot air comes out from its vents, making it difficult to stand near it and it also show vertical lines.
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 12, 2014 | Panasonic PT-AE900U Multimedia Projector
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
THere are an increasing number of white spots (damaged pixels?) on the projection screen. It started with one, and one flickering, now there are 4 clear spots, and another flickers. Can this be solved?
If the spots are well defined rectangular shapes, then DMD pixel failure would most likely be the problem.
You could replace the DMD chip, but it might be more economical to sell the unit as is and buy a new one
Jun 08, 2011 | InFocus IN1102 DLP Projector
My projector (viewsonic pj452) started flickering. When it started it would flicker once in around 5 minutes but now it happens many times in a minute. I tried resetting it from the menu and through reset...
The power supply needs to provide a constant current flow
to the lamp. Any small change or in the current will be seen as flicker
in the lamp and projected onto the screen.
Problem could be with low voltage power supply, the ballast or the
lamp it self is beginning to wear out.
Jul 15, 2010 | ViewSonic - PROJECTORS - PJ452 1500 LUMEN...
Infocus IN10 projector is flickering
it is likely a grounding problem associated with the connection of the power supply to the main board.
Jun 08, 2010 | InFocus LP70+ Multimedia Projector
Our Sharp projector Model PG-B10S is Flickering and blurred text? is this problem associated with bulb?
the flickering could be the lamp, but as for the bluring: if it's pixelated, it's resolution. make sure the computer and projector have the same. if it's not pixelated bluring, it's an optical problem. either the lenses are dirty or misaligned.
Jul 01, 2009 | Sharp Projector lamp Projector Lamp
Dell 3400mp Projector is flickering
Hello. Based on the video, return the projector and get a new one since it is still under warranty. The symptom has nothing to do with the lamp or connections. It appears to be an image processing problem on the main board. The blank part isn't distorted or scrambled, it's MISSING!
Feb 18, 2009 | Dell 3400MP Multimedia Projector
In focus 70+ light flickers
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Aug 06, 2008 | InFocus LP70+ Multimedia Projector
Flickering color, color flickers in and out
Check connections, board, and unit itself around the Color Wheel.
Feb 07, 2008 | InFocus SOFTCASE, LP425Z Multimedia...
Flickering projection
Try changing the refresh rate on the pc video.
Nov 10, 2007 | Toshiba TDP-S8 Multimedia Projector
Hitachi Performa CP-RS55 Multimedia Projector Logo
641 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
