Question about Nikon COOLPIX L18 Digital Camera
Need battery door
Broken because it's plastic and theirs springs and heavy batteries
fighting to get out from behind it...not a new problem
happened with other cameras..need spare doors!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You may order battery covers in a choice of colors here.
Posted on Feb 07, 2012
Dor hinge repair
I fixed my Fagor disgwasher spring last night. The symptom was a bang and the door got heavy. Investigation revealed a broken cord. The parts are available at around 20 UK pounds per pair. They consist of a cord with plastic mouldings at each end. A heavy duty spring sits inside the washer parallel to the door bottom and is streched as the door is opened. I would not recommend buying the spares as getting them off the spring is almost impossible. I had a vice with tools and gave up. Instead I bought some similar cord (try a ships chandler/dinghy shop), one metre should do (99p). Remove the spring and cut the cord off at the moulding. Put the spring in a vice and drill out the cord. Start small (2mm) and work up. Put the new cord through the hole. Bend the spring and use a small screwdriver to fish out the cord. Tie a knot in it. Take a large flatblade screwdriver and open up the coils so the knot will pass through. Drill the other plastic moulding and repeat. The cord length between the mouldings was 280mm but measure the unbroken one. The dishwasher I had a cover clipped in place at the bottom of the door. Lever this forward and the spring is easy to remove.
Apr 18, 2014 | Fagor Dishwashers
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Model QTsi Maxxum. Need a new battery chamber door. The door is broken off. Any ideas?
The battery door on these models just hooks under a wire next to the battery hole. They can pop off rather easily as they are a small piece held in place by a spring, essentially.
You can often find the part on ebay for a few $ and snap it in place yourself. The same battery door is used by the XTsi, HTsi, STsi cameras.
Its very possible that you did not lock it properly the last time you put in new batteries. Hold the door down while you turn the quarter as you lock or unlock it. Otherwise the pressure of the battery spring will prevent a good lock.
LightspiritPhotography.com
Dec 18, 2009 | Minolta Maxxum QTsi 35mm SLR Camera
I have a CANON camera A610 - since i changed the batteries it is not powering. The batteries are new. Please advise the possible problem
Double check that the new batteries are actually good. Note that so-called "heavy duty" batteries are terrible for use in digital cameras.
Next thing to check is the battery door slide switch. This is a tiny black micro-switch in the the battery compartment. It's activated by a tiny plastic piece on the battery door slide mechanism that may have broken off.
Dec 17, 2009 | Canon Cameras
Broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Dec 14, 2008 | Dishwashers
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
Broken battery door
This guy on eBay - Darntoothysam has them for replacement/repair
http://cgi.ebay.com/Kodak-DX6340-DX-Camera-Parts-Repair-BATTERY-DOOR_W0QQitemZ250155840074QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 13, 2007 | Kodak EasyShare DX6340 Zoom Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
87 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
