Question about Tanita Health & Beauty
Measurement is in kilograms instead of pounds
My tanita tbf-612 scale has switched to metric when the batteries died. How can I change it back as there is no switch on the back to do so.
Check if there is a tiny whole in the back you could probably poke it with a needle
Posted on Jan 03, 2009
Why will my bathroom scales, Model TH 321 not show weight, but only zeros?-
SOURCE:Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Jan 02, 2018 | Health & Beauty
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
Getting error E 11 on unit.
ok here is what I found: •E - 11 is displayed when there is a loose connection between the control box and the weighing platform.•Confirm that none of connections between the scale and control box are loose or unplugged.•There may be excessive vibration which will disturb the measurement process.
you can dowload the manual here http://www.tanita.com/en/tbf-300a/184-catId.520093719.html. If those solutions do not work i reccomend contacting the manufacturer here http://www.tanita.com/en/contact-us/ as the unit may be under a warranty.
Apr 01, 2009 | Tanita TBF 310 High Capacity Pro Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Method 2
Mar 15, 2009 | Health & Beauty
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Nov 10, 2008 | Tanita Digital Body Fat Scale with 2...
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Health & Beauty Logo
430 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
