Question about Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
  • Anonymous Mar 16, 2014
    The scale continues to blink 8888 and will not set to zero. I've changed the battery and still the same problem. I've tried setting something on the scale. Continual blinking of 8888.
  • Anonymous Mar 31, 2014
    every time i turn on the scale its displays errrh i tried removing batteries cleaned it real well now i dont know what else to do to get past this errr
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
Tanita machine model tbf 300 a does not print
Posted on Jan 22, 2014
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
My scale is now set on pounds. I would lik to change back to Metric
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Tanita TBF 612 Body Fat Monitor Scale, don't know how to use it
Try here:
http://personalcare.owneriq.net/manuals/mfg/tanita/tbf612_1.html
Jul 04, 2009 | Health & Beauty
Getting error E 11 on unit.
ok here is what I found: •E - 11 is displayed when there is a loose connection between the control box and the weighing platform.•Confirm that none of connections between the scale and control box are loose or unplugged.•There may be excessive vibration which will disturb the measurement process.
you can dowload the manual here http://www.tanita.com/en/tbf-300a/184-catId.520093719.html. If those solutions do not work i reccomend contacting the manufacturer here http://www.tanita.com/en/contact-us/ as the unit may be under a warranty.
Apr 01, 2009 | Tanita TBF 310 High Capacity Pro Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
Measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Jan 01, 2009 | Tanita Health & Beauty
Setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Nov 10, 2008 | Tanita Digital Body Fat Scale with 2...
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Health & Beauty Logo
1,221 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
