Question about HP Pavilion dv6000z Notebook
Keyboard replacement Some of the letters came off my notebook keyboard. I have a new keyboard and need to know how to remove old and install new. thanks, wayne
  • snapper825 Jan 01, 2009
    Thank you very much!!
    I have my new kb installed and working.
    wayne
    wayne
    Sergeant:
    Novelist:
  • 326 Answers
A key fell off the laptop keyboard. Fixing the problem.
One or more keys fell off the laptop keyboard and you are not sure how to put them back? Don’t worry, most likely you can fix the keyboard and it’s not necessary to buy a new one. There is no universal repair guide because all keyboards are different. Here’s what I usually do in this case.
Situation 1. The key cap and key retainer fell off the keyboard and you cannot figure out how to assemble them back.
keyboard replacement - keyboard-key-repair-1.jpg Carefully remove the cap from any other working key so the key retainer stays connected to the keyboard.
Take a closer look at the key retainer, it’s connected to the keyboard at four different points.keyboard-key-repair-3.jpg Assemble the disconnected retainer the same way as one on the keyboard and put it back in place.keyboard-key-repair-4.jpg Put the key cap on the retainer and snap the cap back in place.
Posted on Jan 01, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Perhaps the best would be an illustrated how to? Pls click here for a comparable model with nearly identical chassis/components. Additional insights may be gleamed from here.
Good luck and Thank you for using FixYa. Happy New Year.
    Sergeant:
  • 183 Answers
    President:
  • 2,110 Answers
Okay, to start with, you’ll need:
  • Replacement keyboard (Part# 431414-001)
  • Phillips Head Screwdriver
  • Flat Head Screwdriver (for prying off cover)
keyboard replacement - step-1-thumb.jpg?w=500&h=331
Step 1: Remove RAM cover and Battery
Use your Phillips screwdriver to remove the two screws securing theRAM cover, and set it aside. Then remove the battery as well.
step-4-thumb.jpg?w=500&h=331
Step 2: Remove Necessary ScrewsThere are a total of eight screws that you’ll need to remove to getto the keyboard: Five black screws, and three smaller silver screws.
step-6-which-screws-to-remove-thumb.jpg?w=500&h=331
You’ll see a keyboard icon next to the three lower screws:
step-5-keyboard-screws-thumb.jpg?w=500&h=333
And these are what you should end up with after removing the screws.
Step 3: Remove Keyboard Shield
Next, we’ll have to remove the shield that holds the keyboard inplace. You can do this using the Flathead screwdriver, fingernails, ora coin.
step-9-cover-popped-up-thumb.jpg?w=500&h=331
You’ll pop them up like the image above on botkeyboard replacement - step-10-cover-off-thumb.jpg?w=500&h=331s.wordpress.com/2007/10/step-10-cover-off.jpg">step-10-cover-off-thumb.jpg?w=500&h=331
Once you get the cover up, be careful not to damage the flex cables beneath it.
Step 4keyboard replacement - step-10-removing-keyboard-1-thumb.jpg?w=500&h=332ress.com/2007/10/step-10-removing-keyboard-1.jpg">step-10-removing-keyboard-1-thumb.jpg?w=500&h=332
Now that you have the shield loose, you can now remove the keyboard.There is another flex cable connecting the keyboard, so don’t pull toofar up on keyboard replacement - step-11-careful-with-ribbon-cable-thumb.jpg?w=500&h=331wordpress.com/2007/10/step-11-careful-with-ribbon-cable.jpg">step-11-careful-with-ribbon-cable-thumb.jpg?w=500&h=331
Carefully work the keyboard replacement - step-13-remove-ribbon-cable-thumb.jpg?w=500&h=331een.
Now you’ve gokeyboard replacement - step-12-keyboard-removed-thumb.jpg?w=500&h=331reinstall the new one. Almost there!
step-1keyboard replacement - step-14-reinsert-ribbon-cable-thumb.jpg?w=500&h=331mi
Step 5: Install the New Keyboardstep-14-reinsert-ribbon-cable-thumb.jpg?w=500&h=331
First, carefully insert the new cable into the slot. Be careful not to damage it, the cables are fragile.
Update: “The connector slot has a lever the pins are connectedto the white box and the black lever at the bottom of the white box canbe pulled towards the screen. This will keyboard replacement - step-15-reinsert-the-keyboard-thumb.jpg?w=500&h=331 back it will fix the cable.” Thanks, alexfor the tip!
skeyboard replacement - step-17-back-latches-of-cover-thumb.jpg?w=500&h=331 class=
Now, place the keyboard back down inside the case.
Now we’ll replackeyboard replacement - step-16-pop-covers-back-on-thumb.jpg?w=500&h=331e sure the back latches set in place correctly, then pop thesides back down into the case until you feel them lock.
step-16-pop-covers-back-on-thumb.jpg?w=500&h=keyboard replacement - step-18-small-screws-go-here-thumb.jpg?w=500&h=331t All Back Up</i><i>Now that you’ve got the keyboard back on, flip it back over onto its back, and reinstall all eight screws.</i><br /><i><a rel='nofollow' href=
Don’t forget, the three small screws go here, under the battery.
step-6-which-screws-to-remove-thumb1.jpg?w=500&h=331
Now, we’ll put the RAM cover back on…
…and put the battery back in.
And that’s it! As long as you’ve got the cable plugged in correctly, it should work with no problems.
step-20-done-thumb.jpg?w=500&h=755
    Genius:
  • 3,422 Answers
HI,
Please let me know the make and model no. of your laptop so that i can send you the instructions with pic.
  • 3 more comments
  • Priya darshan Jan 01, 2009
    I will be waiting for your reply.
    Here is our four step guide on how to replace laptop keyboard.
    How to replace laptop keyboard tutorial can be better understood if you have a fair idea about the keyboard itself.
    So let's look at the picture of a disassembled keyboard and
    identify some of its parts to which we will be referring frequently
    from now on.
    This is a view of a standalone dell latitude d505 keyboard from the front side
    In the above picture the demarcated red circles referring to 1 and 2 contain the fastener holes of the keyboard through which the keyboard is attached to the system board.
    We need to unscrew the fasteners in order to release it from the laptop base. More on that later...
    Now let's see how a keyboard looks from the back and what all connections does it have?
    In the above picture, 3 shows you the location where you can
    find the part number which is required when you are ordering a
    replacement laptop keyboard. It also gives you some information
    regarding the manufacturer of the keyboard.
    4 encircles a pin connected to a black cable.
    Any idea why it's there?
    Well, It's the transport system for all the information that
    you punch in onto your keyboard. This cable transports your input
    information to appropriate locations for processing. This cable has a
    pin at its end denoted by 4 which goes into a socket on the motherboard.
    We will show you the exact connections in a later picture,
    because right now it's time to get into the first to do step of our how
    to replace laptop keyboard tutorial.
    Step1: Before replacing a laptop keyboard
    you need to
    • Remove the AC power
    • Remove the battery
    • Remove the keyboard bezel
    After all this is accomplished, your laptop would look somewhat like the dell d505 we operated on shown below
    The highlighted zone shows the area where the bezel rested. After it
    is removed, the keyboard fastener attachments are exposed for
    unfastening and that is what we are going to do in the next step.
    Let's move to Step2 of the how to replace laptop keyboard tutorial.
    Laptop keyboard replacement is child’s play once you have removed
    the keyboard bezel. After that all you need to do is unscrew it from
    the system board and then pull off a plug from the socket.
    But it’s easier said than done.
    However you need not worry because we will walk you through the above steps taking one at a time.
    Now let’s get to step2.
    Step2: Those troubling screws
    Earlier we had seen fastener holes in the keyboard through which screws run (see the keyboard picture for label 1 and label 2). These are the ones that fasten the keyboard on to the system board.
    Now we will take a screw driver and unfasten those screws, as shown in the picture below
    After all this effort we are ready to move on to the next step of
    this laptop keyboard replacement project which deals with other
    keyboard/system board attachments.
    Setp3: Dealing with the cable
    Now that you have pulled off all the screws, take the keyboard in
    your left hand and gently pull it in the direction shown. You will
    observe that a cable from the keyboard is attached to the system board.
    It’s the same data cable we talked about earlier and it is attached by the plug shown as 4 in the previous page.
    Next we will gently pull off the cable plug in vertical direction such that it comes out of the socket.
    Why don’t you have a closer look at the plug-socket attachment
    Step4: Keyboard in your hand
    At this stage your laptop should look something like the dell d505 shown below
    In the picture above the label 5 shows the socket that is attached to the motherboard. This is where the cable plug of the keyboard is attached. The rectangular boundary is where the keyboard sits.
    You can place the keyboard back in it’s position by following the four steps in reverse order.
    That brings us to the end of this laptop keyboard replacement tutorial.
    Here are the pics:
    Here are some more:
Letters popped out of computer keyboard
If it is a laptop, you will need to get a replacement keyboard or actual key, remove the old one and put in the new one. A key that is popped off is usually broken.
Jan 26, 2013 | Computers & Internet
Dropped liquid on my keyboard and two letters plus shift do not work what can I do
unfortinatly liquid on keyboard means u need to buy a new keyboard you can find them on ebay and there easy to install i know it sucks i ve ben there i just used a regular one or the on screen keyboard
Jan 18, 2011 | Toshiba Satellite Pro L300 Notebook
Mac laptop keys are not showing letters but symbols and delete key not working. How do I unlock this problem?
There could be a couple of possibilities :-
1. Faulty keypad
2. IC on the main board
Faulty keyboard is more often a problem. Even though there is no dust and dirt, faulty keyboard may result in all the above said symptoms.If you press a letter key, a symbol might be there. If you press delete key, it might not work. The best option what i follow in my shop is replacement of keyboard. There are certain days when i only replace few keys, but more often if this is a problem with more than 5 keys or with all the keys on the notebook, better to go for a new keyboard.For your laptop, always prefer hard keys as those are more durable than the soft keys.
IC on the notebook is again one of the reasons. This is usually a problem with old laptops, such as 5 to 7 years old. New laptops generally do not have this problem. If laptop IC is at fault, soldering is required to get it fixed.It needs a tech to confirm the faulty IC on the mainboard and then followed by replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 03, 2010 | Computers & Internet
Keboard will ot tpe soe letters
Use the following link to remove keyboard. Once you remove remove the keyboard plug it back in and follow the instructions in reverse to put the keyboard back. If that doesn't work you more than likely have a bad keyboard and it needs to be replaced. If it is still under warranty call dell and they can send you a new one. If it isn't under warranty then you call dell and buy a replacement.
http://support.dell.com/support/edocs/systems/latd600/sm/keyboard.htm#1111863
Sep 13, 2009 | Dell Latitude D600 Notebook
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
My keyboard has letters that just stopped working, bad news is the letters are part of my password authorization! I bought a new wireless keyboard BUT because the password authorization is the first thing...
i would buy a replacement keyboard for it. most of the time you should be able to find one for cheap on ebay. they are fairly easy to replace and only require popping off the plastic trim on the top edge of the keyboard, removing a few screws and the data wire. then connect and screw in the new one and pop the trim back in place.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
My ;keyboard is typing random letters on the right side of the keyboard p is pi or ip, i is ip or ip, k is k;, comma is , ; semicolon is ;k zero is 80 and 8 is 08 that is all I have found so far.
You most likely have a defective keyboard. Call Dell Parts (800/372-3355 x5) and tell them the Service Tag for your computer (it's on the bottom) and they'll send you a new keyboard (and, if you're still under warranty, they'll fix it for you). If you ask them for a keyboard, be sure to ask them for the disassembly and re-assembly instructions to remove the old keyboard (there're lots of other small parts you'll have to remove to expose the screws that hold hte keyboard in place).
Apr 09, 2009 | Dell Inspiron 2200 Notebook
Top row of letters on keyboard not typing.
If newer BIOS doesn't help, - new keyboard.
Jan 21, 2009 | HP Pavilion dv6000z Notebook
Several letters on a keyboard have stopped working
Bring it back to the repair shop. They should replace the keyboard.
Dec 02, 2008 | HP Compaq Presario v3000z Notebook
Fitting new keyboard
Link for dv2000
Page 127 of the PDF starts the keyboard disassembly.
Apr 06, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
