Question about NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch
2.4 nolt working, opnly 5 available
When plug/unplus, both work, but then 2.4 light goes solid and 5 blinks...only computer with N capability can then pickup and other laptops cannot. djh
    Sergeant:
  • 366 Answers
Configure your Router.
Let me know if you know How-to.
Posted on Jan 03, 2009
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
Power was turned off to the house. When power came back the router is blinking blue lights and can't see the modem. Disconnected the computer from the wireless and plugged directly into modem and it's...
just as a guess try unplugging power to both modem and router, then plug only modem in first until connection light stops blinking and goes solid. then plug in router.
Dec 23, 2010 | Linksys WRT160N Wireless Router
No power PC is dead tried a spare power supply and PC works.. Green led on rear of power supply blinks all the time.when disconnecting 110v ac plug light then dims still blinks but slower then goes...
the original psu is dead toss it. the one you are using is not powerfull enough to run the pc. check the old opne for how many watts. then check the new one. i bet the new one has fewer. so to solve problem get a psu with the same or more watts than the old dead one.
Jun 20, 2010 | Bestec (ATX100-5) (ATX1005B) Power Supply
I have a road pro rppi converter light links
It blinks because your computer is drawing too much current. Most of these give an exaggerated wattage range, and never give details about the true amperage available. the average laptop uses 3.0 to 4.X amps and is too much for these mini inverters. But they work fine on cell phone chargers.
Mar 24, 2010 | RoadPro AC/DC Power Inverter 80/100w
Modem light is blinking no internet light
hi, there are two ways to assit you on this issue.Either you can call belkin customer care which is a TOLL FREE no. on the product box and get assisted or else proceed with the following basic steps.
1. the product that you have is an obsolette.
2.Before troubleshooting the belkin product. Please connect your computer directly with the modem (without router)on the ethernet(lan) port and check for the solid lights on the modem after turning it on, after that check for internet connectivity, if you can go online, its fine else you need to contact your modem vendor and get fixed.
3. if u can go online, then connect your router isolated port to the modem amd your computer back to the router's lan port(port 1) and check for the solid internet,power,modem,lan lights on the router.
4. if all are solid lights , check you can go online else you can hold the reset button at the rear side of your router for 2 mins if you have a cable modem and then check for connectivity.
5. If you have a dsl connection , then better contact customer care, they assit you very well.
Sep 21, 2009 | Belkin (F5D6230-3) Wireless Router
Sandisk cruzer micro code 10 error
This can be due to a internal problem,,,also can be avirus
The light should be in solid state i it's working right...and blinking only when a transaction is happening
Please don't forget to rate me "FIXYA"...thank you!
Mar 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
All lights blinking
Try:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
May 05, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
Got it from here:  http://www.fixya.com/support/t612015-print
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Logo
53 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
