Question about Maytag Neptune MAH5500B Front Load Washer
Will fill with water but not continue with rest of cycles
I believe it is bad control board and motor. i was told that there was a 10 year warranty on control board and motor. is this true? model#mah5500bww
    Sergeant:
  • 311 Answers
Hey i like that washer i have one too.so no tumble after fill? just dead! that may be boards because door latch would come into play a minute later.your wiring diagram in the consoel will give you some clues.you would have to call maytag on any board warrenty.but i dont think its that long.God bless ,tom
Posted on Jan 01, 2009
Kenmore elite 90 series 11028902790 fills w/ water & agitates. On drain cycle it won't drain unless you put drain hose to floor drain position. Drains water but will not start the spin cycle. Help
It is either a bad pump or a bad control. Call Sears. Hard for the homeowner to fix. If not in warranty, ask them how much to fix and then decide if the old one is worth the money. If the machine is 10 years old, go for a new one.
Jun 01, 2015 | Kenmore Washing Machines
Maytag MAH6500
yes there is a control board at the back of the machine if it got wet it will be damaged and eventually the machine not might work at all its easier to call a repair man instead of all the trouble doing it your self and it is int costly at all
Sep 09, 2008 | Maytag MAH6500 Neptune Front Loading...
I have a Bunn BTX-B. It just stopped heating the water. I received it as a Christmas gift, purchased on Dec. 24, 2010, from Lowes. I do not have the receipt. I emailed customer service. They sent me two...
Warranty is 1 year parts and labor, 2 years parts only and 3 years for control boards. That model does not have a control board. You could have a bad thermostat, bad high limit, bad thermal link or bad element. Without you having a multimeter anSd the knowledge of how to use it properly it would be best to replace the unit.
Dec 27, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Lr has shown up on my washer MAH5500BWW, it had benn sitting for 3 years, hooked it up and the first 2 loads came out great and then the third will not ring out ?
Hi
Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and motor windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Washing Machines
After working perfectly for almost 10 years, My Miele dishwasher G 664 doesn't fill in water. We replaced the Pressostat and it didn't solve the problem. My technician suggests that the motor is off and...
In my professional opinion with a 10 year old unit. Buy a NEW unit, with a warranty, and do not spend good money after bad, as they say, a unit of this age will simply continue to fault, over and over, as it gets older.
Aug 03, 2010 | Dishwashers
Maytag mah5500bww motor/control board failure recall
I had Maytag ship a new motor and motor control board for free and installed it myself in less than an hour. There is a ten year warranty on those parts. You just have to be very firm and insist you have warranty rights by law!
Feb 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
What is the difference between the LG WM2016 and the LG WM2010
The 2010 has a second rinse cycle, while the 2016 doesn't. Also the 2016 consumes a lil more electricity than the 2010 but thats probably because it's a lil bigger.
May 28, 2009 | LG WM2016C
Lr code on display
it is a problem with the motor .this is confirmed.
Issue
Washer stops in mid-cycle and/or flashes a code.
Warranty Standard product manufacturing warranty applies.
Action The motor drive system experienced a momentary loss of neutral feed from the power cord to the
Motor Control Board. The neutral line for the Motor Control Board passes across the water valve
solenoids. Neutral to the motor drive system can be momentarily lost If there is poor crimping of any
of the wire terminals in this circuit. This situation could result in a misdiagnosis and unnecessary
replacement of the Motor or Motor Controller Board.
Current Neptune front load washers will indicate a false locked rotor signal to the Machine Control
Board. Washers with a LED display will flash code “LR” in the display. LCD washers will display
“Locked Rotor.” The earlier built front loaders will not display a code, but simply shut down in midcycle
or will not start.
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the
wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure
the wires fit snug on the terminals of the water valve solenoids.
A product improvement has been made to the following models. The neutral wire is routed across
the pump only, and now by passes the water valve solenoids.
MAH55FLBWQ/W ..................... Series 12
MAH5500AWQ/W ..................... Series A7
MAH6500AWQ/W ..................... Series 33
MAH7500AWQ/W ..................... Series A6
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
Maytag Neptune MAH5500B Front Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
