Question about Fujitsu Siemens CELSIUS Notebook
The "h" key types "h6' and my "F" key types "f4" what happened?
I cleaned the computer with some glass cleaner and it strated malfunctioning.
Hi, I have gree air-conditioning and its had H6 malfunction code. What should I do?
Clean the filter. Then press on button for 5 seconds to clear code. Good Luck
Apr 05, 2017 | Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
What do i need for a tuneup
What type of vehicle? Most newer vehicles are controlled/monitored by the computer. Spark plugs are designed to last 160000km on most vehicles. A lot of newer vehicles do not have much of anything to change tune-up wise these days. Fuel filters are in the tank in most vehicles. Need year make and model as well as mileage to point you in the right direction
May 03, 2015 | Computers & Internet
My phone jammed
Use a Glass cleaner to wipe the keys of keyboard. After your usage is over cover it with a cotton cloth so as the keep it free of dust .Just spray and wipe it cleans ..you may use " MYCOOL " CLEANER.
Apr 09, 2014 | RIM Curve 9380
Where can i find the minute and second key
In Run screen, press OPTN>F6>F5 (Angl). The Degree/Minute/Second key is the TAB above the F4 Key.
To use the key for example to type in 58 deg 33 minutes, 27 seconds type in 58, press F4, type in 33, press F4, type in 27 then F4. Press EXE. The screen displays 58.5575.
A new tab appears above F5. Press it to convert displayed result to DMS
Feb 08, 2013 | Casio FX-9750GPlus Calculator
The enter key doesnt work
What program are you trying to access ?
The enter key is usually used for DOS command prompt.
or when typing in passwords to enter certain programs or computers and email accounts
click stat type into search cmd press enter a black screen should open
It might be a problem with the actual enter key on your keyboard.
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean hope this helps
Dec 10, 2012 | Panasonic Toughbook 19 Laptop Convertible...
C0f22 error code
Atomatic Intensity Density Cotrol sensor malfunction.
Clean the optical parts:lens,mirrors and original glass.Remove the OPC unit clean the AIDC sensor under drum in the rear side,use the vacuun cleaner for remove the used toner under cleaning blade,reasamly the unit.Clean the transfer and separator corona holders and wires and perform the F5.Enter in the service mode Stop key-0-Stop-1 Function menu ,place A3 sheets in the original glass place and perform F5.See the F code history and reset it.This code reset if you open and close the front door.
Sep 09, 2009 | Minolta EP4000/5000 CS/PRO Copier
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
May 11, 2009 | Sharp Office Equipment & Supplies
Incorrect key assignment
do you have an fn key anywhere on your keyboard
Feb 08, 2009 | Dell 0Y3740 Keyboard
Keyboard problem
turn of the number lock holding 'fn' key + 'num lock' key on your keypad...thats all
Dec 21, 2007 | HP Compaq Evo n610c Notebook
Fujitsu Siemens CELSIUS Notebook Logo
126 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
