Question about Pioneer AVH-P7480 Car Video Player
Does not work??
I have a pioneer avh-p7480 unit. i hooked up all the wires the right way and checked all my connections. I used a wire harrness to mke things easy. And checked all my fuses. However,the unit will not come on at all. It does not even light up or show any signs of well anything.
SOURCE: Which navigation unit do i need for the AVH-P5700DVD? AVIC 80DVD,AVIC 90DVD,AVIC 9DVD
try the avic 880dvd or the avic 88dvd
Posted on Mar 27, 2008
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at You can refer to the installation manual for your deck at Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
  • 33 Answers
SOURCE: parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Posted on Feb 11, 2009
  • 18 Answers
SOURCE: bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Posted on Jun 10, 2009
SOURCE: I have a Pioneer AVH-P6500DVD in dash dvd player.
dont buy stolen merchandise
Posted on Jun 22, 2009
SOURCE: do u need the brain to hook up an amp to a Pioneer AVH-P6600DVD C
that makes no sense, if you have the 6600dvd all you're going to need is the rca outputs. you don't need the brain aka hide away box. hode away box is only for the untenna and more monitors.
Posted on Jul 09, 2009
0 characters
1 Points
I have a pioneer in-dash avh-p5100dvd and it has so many wires and I dont have the wire diagram how can I figure out what wires go to what so I can hook it up properly
Get the plug to wire unit to and then plug it into the car; Don't cut and splice the wires. It looks bad and you can cause allot of problems. Also if you sell the car and want to keep the unit just unplug it and reinstall the factory unit.
Aug 02, 2015 | Pioneer Car Video Players
My Pioneer AVH-P1400dvd wont cut on after installing it
Did you make sure you connected the Blue wire to the pioneer its the remote to the car when the car is on the device will be on if you don't connect this wire the device will stay on
Dec 28, 2013 | Pioneer AVH-P1400DVD
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Video Players
My Pioneer AVH-P5700DVD's screen is very dimmed i can bearly see the buttons, it seems like there is no brightness in the screen please help... I checked everything already... Maybe is a dim adjustment?
it could be a dim adjustment. did you hook up the dimmer wire to the factory harness if so and your dash lights are low then thats the issue. if not then check the brightness on the unit. if that is not lowered then the internal lights inside the unit have started to burnout. if thats the case uninstall it and send it in for repairs
Nov 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
hope this helps,......
Mar 07, 2009 | Pioneer AVH-5700DVD Car DVD Player
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
The brown wire, according to the installation manual, is the "Mute Wire". Their instruction is:
"Connect to the terminal that is grounded when either the telephone rings or during conversation."
So this appears to only be necessary if you are also using a mobile phone with your system.
The orange/white wire is the "dimmer control" lead, which should be wired into the switch that turns your car lights on and off. This will probably allow your head unit to dim when you turn the car lights on (night time).
Hope this helps!
Jan 10, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
I need help
unfortunately, although the p7480 has the dvd player built in, the decoding, audio and menuing system are built into the brain (8000r/9000r). you can try inserting a disc, but i have never had any success without the main tuner hooked up. the good news is your screen and player are compatible with the 8000r and 9000r, and these can be found on ebay and the like for 50-200 bux or so.
hope this helps,
Nov 15, 2007 | Pioneer AVH-P7480DVD Car DVD Player
Pioneer AVH-P7480 Car Video Player Logo
27 people viewed this question
Top Pioneer Car Video Players Experts
Craig Sagar
Level 1 Expert
Phil Sowers
Level 1 Expert
Are you a Pioneer Car Video Player Expert? Answer questions, earn points and help others
