Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher making thumping noise when in cycle and leaking
Dishwasher making thumping noise and leaking from bottom when in cycle
    Sergeant:
  • 311 Answers
Motor turns to cast the water around the dishes.that motor shaft is in close by a water seal.it must have gone bad allowed water on to the motor bearings which would be your noise.could be bad.open your bottem panel turn on unit and watch whats happening.when you see that decide what parts you will need ,check cost and think if thats what you want to do.God bless,tom
Posted on Jan 01, 2009
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher is making thumping noise
We had this problem. It was a bent piece of metal on the bottom of the blade below the bottom rack. Repairman caught it in 10 seconds. Took blade off by turning counterclockwise and lifting it out . Bent the blade back to normal. Sounded great after that.
Feb 24, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Leaking, now humming/grinding from motor
1)wash pump bearing damage(water leaks&leak on winding &bearing etc..,)
2)arrest the leakage &check.
Jan 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Excessive noise
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes. heck your owner's manual for proper loading methods.
Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them.
Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight.
A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Jul 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE Dishwasher makes loud banging noise
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
Apr 06, 2009 | GE Dishwashers
Thumping Noise
it must be due to the damaged belt inside the motor. check it out.
thank you
Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Indesit D63 Diashwasher Trips Electrics
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes. heck your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them.
Hardness (Grains) Tbsp. of Detergent
0 to 3 1 4 to 6 2 7 to 9 3 10 to 12 4
cheers!!!
Jan 14, 2009 | Indesit 24 in. D63 Free-standing...
Code F2
F2= The motor has not
been sensed rotating
 Foreign object has jammed the rotor
 The rotor has failed
 The hall sensor has failed
 The electronic controller has failed
Please check your email
Jul 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Noisey dishwasher
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes; check your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior; be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them. Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight. A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
342 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
