Question about Smeg 24 in. STX2 Built-in Dishwasher
Door wont close
Smeg dishwasher
Is the bottom rack in backwards?
Posted on Jan 01, 2009
My smeg di 612ca dishwasher door will not shut.any ideas?
Check that nothing is protruding from inside of machine. If still won't shut check that nothing is stuck in the closing mechanism. As a last resort contact manufacturer or service agent.
Aug 11, 2014 | Smeg Dishwashers
Smeg dish washer wont stop even when the door is opened,
I never heard of a smeg DW but you can bet the door interlock is hung up in some way. Ususally its micro switches on the latch assy. Then again, could be a bad relay on the control board. I would dis connect the switch first and see what happens. The way I would do that is disconnect power at your circuit box and dis connect the switch, tape off the wire, latch the door and return power. Bet it doesn't run. Most likely the switch assy. Would help to know the right brand name tho...
Oct 16, 2013 | Smeg Dishwashers
Integrated Smeg dishwasher keeps stopping and starting with a beep every few seconds. Tried switching off at mains, filling salt
Try pushing on the door, to see if the stopping/restarting stops, I am guessing your door switch may be wore a bit, and maybe out of adjustment when closing. sometimes the mounting hardware slips out of place, and the door switch in not engaging enough to stay on.
Nov 13, 2012 | Dishwashers
Machine not takin any water
Before starting a washing program make sure that:
• The water supply tap is open.
• The correct amount of detergent has been added to the
dispenser.
• The baskets have been correctly loaded.
• The spray arms are able to rotate freely and without
obstruction.
• The dishwasher door is securely closed.
After you check all start the dishwasher again.
Jun 05, 2011 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
How do you get your dwi612 smeg dishwasher started?
This assumes that you have loaded it, placed detergent, closed it properly, and it is plugged in (with a good outlet)
There are buttons on the top inside edge of the door.
For manual, go to this site It is a PDF document so make sure you can read PDF, and go to page 8 in the document for controls and functions.
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
good luck and don't forget to vote!!!
Sep 28, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Smeg 24 in. STX2 Built-in Dishwasher Logo
470 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
