Question about Zanussi WJS1397W Front Load Washer / Dryer
The spin cycle is faulty
The only problem is with the spin cycle. It seems that it cannot get enough momentum together to begin the spin. It gives a short effort to spin and then dies, it starts to tumble for a short time to re balance the load and then tries again. This is then repeated again and again. Sometimes it will spin if I press and hold down hard on the top of the machine, or if I manually re distribute the load inside the machine.
  • gailforce7 Jan 02, 2009
    Hi, The pump drains out with no problem
    Hi, I pulled out the filter and it was full of fluff, so I cleaned it thoroughly and then put a washload into the machine, it washed with no problem. Then I started the spin cycle and I must admit that the drainage seemed to be a lot more efficient, then guess what? The spin cycle started all on its own!!!!! I cant believe it was just the filter. What an idiot for not not checking it regular. Thanks so much.
    Sergeant:
  • 311 Answers
Question to you is ? it draining all the way if not it cant spin.if not you need to check out your pump it may be blocked or failed
Posted on Jan 01, 2009
  • Thomas Malailua
    Thomas Malailua Jan 02, 2009
    you must be sure of that .ive be fooled as a repairman.once in a while it will drain other it will not,and the water confuses the computer.one i remember i could hold the pump impeller with a toll.that should not be.now if your sure then you have board or motor problems.parts are expensive dont want to guess.had a thought dose your lock lite come on.if not could be failed door switch.
  • Thomas Malailua
    greattttttttttttttttttttttttttt,tom
My LG WM 1812CW turns off soon after the first spin. No error message.
Seems that the main panel is defective. The fault suggests that the program controller or the processor is malfunctioning specially when it works for some time. If you can check on the +5 volt to the processor , the power supply factor can be established as a faulty supply or a blown mains capacitor can also shown this fault .
So remove the panel and check the components for any visible signs.
Jan 14, 2013 | LG WM-2277HW Front Load Washer
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Machine sounds like it will self distruct when spin cycle begins and seems to try to spin too early in wash cycle
If it is trying to go into a spin during the wash cycle when there is water in it then it sounds like your motor is faulty. The motor has what is called a tachometer in it which regulates the spin speed but if it goes faulty it causes the motor to spin up when it is not meant to. Hope this helps.
Apr 14, 2011 | Whirlpool AWM5125/1 Front Load Washer
My washer is making a clicking sound when it is about to begin the high spin cycle to spin the water out of the clothes and is unable to begin the spin cycle on it's own. I have to manually move the knob...
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
Nov 21, 2017 | Whirlpool LSQ9500L Top Load Washer
Whirlpool LXR9445JQ having trouble with spin cycles.
Check the motor and make sure that the RPMs are high enough, Also check the tension on the belt
Feb 12, 2009 | Whirlpool LXR9445JT Top Load Washer
Sometimes won't start spinning cycle
In most cases, this is caused by a faulty lid switch.
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
154 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
