Question about Water Heaters
Have 2 solid state control boards, philips p80c552eba ez zonectlr
Brand new, hate to just toss them, How could I market them?
    Novelist:
  • 148 Answers
Call local plumber ( yellow pages) see if he will purchase at discount of couse you can advertise on craigs list for free under electronics or tools
Some of the tech schools would love to have them but may not pay
if you have a d&l appliance parts co in your area they supply plumbing trade b sure to reference the make and model
Finally you may get a maintenance man at an apartment complex to buy them if they use that type of water heater the localwholesale supplier coud tell you which maintenance companies use that heater
Just call them (wholeseale supplier) and ask who they would recommend to work on that model
Good Luck!
Posted on Jan 01, 2009
Tank is overheating to the point of water coming out of relief valve.
sounds like you have a heating element failing . call a plumber to check
May 04, 2016 | Water Water Heaters
Unit won't operate and there are 4 flashes on the red light.
Two things- Clean the sensor rods or replace(cheap and easy with YouTube instruction video) and at the same time replace the main program chip (also a easy plug in chip). The whole repair takes two hours for a homeowner and costs about 50 bucks for a chip. These are easy an generally the flame sensor rod is the culprit. The code may also be the limit switch but try EZ and cheap first. See You Tube..
https://www.youtube.com/watch?v=npxcVo7RK2c
Feb 27, 2015 | Rheem Tankless Hot Water Heater...
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
Any brand of water heater better than the others? Currently have a Rheem gas 50 gallon
Short answer:
6-year Whirlpool from Lowes, 6-year Kenmore from Sears
Both are same brand. Offer 10% less than price, get store coupons.
Reasoning:
#1 Warranty.
Warranties are same across all brands. First year parts-tank-labor are covered, and afterwards parts-tank are covered for original homeowner and non-commercial installation when installed by instructions shown in manual.
The math shows: shorter warranty has greater percentage of full coverage.
6 year 9 year 12 year?
Only difference is anode rod diameter, or longer-warranty tank may have 2 anode rods.
You can convert 6 year tank into 12 year or 15 year by inspecting anode each 1-3 years, and maintaining tank as shown in product manual.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
# 2 Don't buy tankless.
Don't buy gas or electric hybrid.
These do not save money overall, and do not last longer than ordinary tank heaters, and they are expensive to buy and maintain and repair.
# 3 Ordinary Whirlpool gas water heater from Lowes is inexpensive and can be maintained and repaired by homeowner.
Air intake is located on bottom and can be cleaned easily.
Set 3-legged water heater on bricks so air intake can be inspected and cleaned easily.
Whirlpool is made by AO Smith parent company. Other brands made by AOS are Reliance, State, American, Craftmaster, and Kenmore.
Service manuals are posted online, parts are designed for quick, ez replacement.
Installation manual shows how to perform maintenance.
# 4 Avoid Rheem.
Rheem makes Reliant, Richmond, Ruud, and GE
Air intake can only be cleaned by removing combustion parts. Combustion parts are held in place with tamper-proof screws.
Service manuals are not available online.
Installation manual does NOT show how to perform maintenance, and says that customer must call for service.
Rheem does not offer better product that somehow needs specialized treatment, they just want customers to buy service from brand-loyal plumbers.
# 5 Bradford White makes good heater.
Usually these are more expensive and not available except thu dealers who might require pro installation for warranty coverage ... maybe.
Are BW made better? Warranty is identical to other brands.
Must remove combustion parts to clean air intake.
Parts are ez to replace, but they might not sell parts direct to homeowner.
Service manuals are available.
# 6 Insulation thickness.
Does not make much difference with current price of gas.
If you pay $400 more for a tank with 2" insulation instead of typical 1-1/2", then payback can be 15 years or more.
Oct 24, 2012 | Water Heaters
Water not as hot as it was.
Tankless require yearly service to keep burner and combustion parts clean and check electrical connections, gas solenoid, gas pressure, venting, etc.
Read product manual for advisories and recommended maintenance.
Yes, aren't you glad you saved the manual.
Always check that local area has affordable and qualified service technician for your brand before buying tankless.
Before calling service technician, copy following link for general troubleshoot resources, including some manuals, and links to Bosch.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Try turning temperature down.
The fact there is no error code, and the gas is not firing correctly, means you have a small unit with no error codes and PC board has failed ... or it means you have a unit with error codes and possibly bad PC board.
If problem is the PC board, then Bosch will send you new board, and expect same level of repair success as though your computer's motherboard was replaced.
You can buy ordinary box-store tank-type heater and install yourself same day for about $325.
Then maintain and fix it yourself. I recommend AO Smith/American/State/Reliance/Kenmore/Whirlpool since these are easy to maintain with clear directions in manual, plus AO Smith posts service manuals for the whole line of products, and any local plumber can fix them with ez-to-locate generic parts.
Sep 07, 2012 | Bosch & Tankless Water Heater
Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Jul 24, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am getting error code C7 76 on model RTGG 53DVN
is a connection between your controller and the unit disconnect the controller and see if it runs if not then it could be the PCB board. check your wires for bad connections on the remote as well
Jun 27, 2009 | Rheem Tankless Hot Water Heater...
No hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Heating_Systems_Water_Heaters_Cold_Water_Still_Released_Despite_Water_Heater.htm
Hope this helps.
Brad
May 11, 2009 | Water Heaters
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
Water Heaters Logo
79 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
