Question about SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow
USB problem My simpletech 320 GB is not connecting
  • Thomas F. Schneider May 11, 2010
    Did you receive setup software with the device? Is it installed?
    Novelist:
  • 151 Answers
I) connect it at the backside of your computer(in the usb ports), mostly these(usb with huge space) are not compatible with usb ports on the frontside or front panel of your computer tower...
Thanking you,
M. Sridhar
Posted on Jan 01, 2009
Simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
I have a SimpleTech 320 GB external hard drive. It suddenly stopped appearing in My Computer. When I turn it on, it makes a repetitive sound that seems like a warning of some kind...what is it? It sounds...
Hello and welcome to the TSF. If the external drive has provisions for external power you'll need to plug that in, usb ports cannot power a 320 drive. If the drive has 2 usb plugs (one for additional power) you'll need them both plugged in, and I would suggest that the laptop should also be running off of external power rather than battery. If you disconnect the usb drive or any other usb device without first stopping the device then sometimes the usb ports will fail to recognize the device when it is plugged back in, a simple reboot should do the trick. You can also check in the device manager for any yellow exclamation marks on your usb host conrtoller and see if the driver for it is in need of an update.
Any drivers you need should be on simpletech's website, though normally you should not need any for a usb hdd. If the power cord/a/c adaptor is faulty or the hdd is loose in the enclosure(thus not making good contact) then you should pester simpletech to either replace the cord, a/c adaptor,or unit, and see if there are instructions on how to take apart the enclosure and reseat the drive/connections.
__________________
Nov 07, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech drive
Using this program http://www.ridgecrop.demon.co.uk/dow...at32format.zip
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
MISSING STORAGE SPACE
HARD DRIVE NEVER SHOWS TOTAL.ITS BECAUSE OF A CONFLICT CONCERNING WHAT SOME SAY IS A GB. ITS NORMAL AND YOUR DRIVE FINE.RELAX AND ENJOY.RICHARDM69
Dec 06, 2008 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech Signature Mini 250GB External USB 2.0 Hard Drive - White Marshmallow Logo
548 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
