Question about Epson Stylus CX6000 All-In-One InkJet Printer
Print head on Epson CX6000 stuck on the right side.
When I turn the printer on it makes a grinding sound and the head tries to move but it can't.  I can't move it by hand either.  All this happenned after a paper jam.
    Problem Solver:
  • 10 Answers
Obviously, something is preventing the print head from moving. Turn th printer off and try checking for obstructions inside or any foreign material. If it does the same thing when you turn it on then you might want to have your printer checked by a technician or you can contact Epson tech support for warranty options.
Posted on Jan 03, 2009
Epson Stylus CX6000 inkjet printer. Problem: Print head assembly jammed while traveling from left to right. Now it won't move, so can't print. I'm handy, can I do something? Or do I need a service...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson r220 print head goes left and then makes a grinding sound
Your printer needs a service reset. Epson printers will only accept x number of cartridge changes / print head cleans. Basically it's telling you that the waste ink pad is saturated. It will cost about £30.00 from a local service centre
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Dec 08, 2008 | Epson Stylus C84 InkJet Printer
My epson stylus C42UX printer cartridge is getting stuck
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right hand end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below), or some other mechanism fault.
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above! If you want to have a go at doing this yourself, please report back for help on this.
If neither of these apply, please report back for further help.
Nov 24, 2008 | Epson Stylus C42UX InkJet Printer
Epson cx6000 will not print
Have you tried replacing the cartridge....to verify
keep me posted
Cheers
Nov 13, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson stylus photo R 230 series
unless the head come to a halt during initialization process, upon turning on your printer there is no way you will be able to print, please check for any obstruction on the printer head, the grinding sound is an indicator that the head is trying to reach its position and was having trouble. or it could be a damaged belt that you need to replaced
Jun 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer carridge
Turn the printer off. Then move the print head back to the center with your hand and turn the printer back on.
Feb 16, 2008 | Dell Photo 964 All-In-One InkJet Printer
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
203 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
