Question about Samsung ML-3561ND Laser Printer
Fuser Door/s Regarding error message "Close Fuser Door" What is it? where is it? how do I close it? Colin
  • Anonymous Feb 11, 2009
    i have bot same problem but i couldnot solve pls help.
  • Anonymous Mar 14, 2014
    display message Door is open. Close it
  • 40 Answers
Your Samsung ML-3561ND looks to be an HP Laserjet 4000-series printer. Same engine, different electronic. The fuser is in the rear of the machine, and may be relating to the drop-down rear panel where you clear paper jams. Open it and give it a good push closed and the printer should cycle and come ready. Let me know what happens!
Posted on May 29, 2007
The fuser door is a metal flap under the toner cartridge (so accessed via the top cover) with a green tag on the right hand side - at this position there are two contacts. If just making sure the fuser door is fully down fixes things - that's good; otherwise there may be an issue with the sensor components.
Posted on Sep 13, 2007
  • cdn-2007
    cdn-2007 Sep 13, 2007
    I might be mistaken above ...
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Front or vrear cover open
there are 2 switches regarding this error message " front and rear cover open." so pls. check with the front door right side portion. you can see a small leaver there, pls. check that liver correctly go inside the cover after we close the front door.
other switch at the back door paper exit area. pls. check the door closed properly nor not ? that door control a switch liver attached with the fuser unit.
first switch in the HVPS board and second switch at SMPS.
kindly check it and revert back.
May 05, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Hie, i have a problem with two printers, the canon ir2000 and the canon ir2010 it first gave me the error E000 message i resseted it then it now gives me the "check printer cover" message, what...
Error E000
Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000
Error "check printer cover"
I think your problem is fairly simple if you have technical background. just check door compartment carefully there is a plastic part which presses the sensor switch or cover the optical sensor may be broken.
If not, then take a digital meter and ground the common probe and positive probe touch to the related sensor.there are two type sensor 1) switch type 2)optical, that they use.
If the switch type is used, when door is open voltage is 0,door close voltage is 5 volt although this may be reversed.
In the optical sensor case, one side is diode that is on 1.5 volt and other side photo transistor.
connect probe to trs side to collector or emitter depending on what biasing they use, then open door and see if the emitter goes high or low, repeat in door close position also if it goes properly high and low, if not then some other part is faulty.
If you are not sure how to do this then call in a technician
Jul 26, 2011 | Canon Office Equipment & Supplies
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Turn on get error c0500 on a minolta ep4050
the error codes means Low fuser temperature during warm-up
Jul 06, 2009 | Office Equipment & Supplies
142.10 Service Motor Error
my dear Your printer's lower door must be completely closed before the upper door is rotated downwards and closed.  If you close the two doors at the same time, a mechanism inside the printer may become dislodged and return an error message. heres the step i teach to you, it is not a fake this is my thrisck , and many people are success of my guide, hope it was also helpfull to you. step 1 Power off the printer. Remove the fuser assembly and carefully set it aside.
Locate the link on the top right side of the printer where the fuser used to be. Using the eraser-end of a pencil or similar tool, reposition the link into the metal track. Once the link is positioned, rotate the upper door while holding the link in position to ensure it travels properly along the metal track. Replace the fuser and secure the thumbscrews. Power the printer back on to see if the error has cleared. If the error persists, contact Lexmark technical support for assistance. or just tell me for confirmation. thanks god bless
Nov 28, 2008 | Office Equipment & Supplies
Samsung ML-3561ND Laser Printer Logo
2,570 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
