Question about Lands Phones
Can't dial abroad
I tried calling my sister in Austria and I know the number is correct and the telephone says the number you have dialled has not been recognised.
This same answer comes when I try to call a friend in Norway and I believe I have that number correct as i have dialled it before.
So why is our telephone working normally for outgoing and receiving UK calls but not working for calls abroad?
01628 521651
  • 69 Answers
How are you dialing the number on the phone, what is the number, if your are not dialing it correctly it will cause this,
i.e i believe austria is 00 + 43 + Area Code+ Tel #
and norway is 00 + 47 + Area Code+ Tel #
if you go to www.countrycodes.com this will help
Posted on Jan 01, 2009
Phone was played with by child, now red light shows and no dial tone
Hello
Your phone ahs been locked by mistake. When telephone is locked, except for a saved emergency number, no numbers can be dialled; incoming call can be answered.
To unlock it, Lift Handset, select function. (1) Lock. (0) Unlock. Press SET key and replace handset. OK.
Aug 30, 2011 | Siemens Euroset 5010 Corded Phone
Area phone code please for the isle of white
The code for Isle of Wight is 01983
Dialling from abroad
To dial 01983 from abroad, dial the international access code followed by the country code for the UK (44). Proceed to enter the local code 01983 without the first zero e.g. 1983 followed by the remaining telephone number
Aug 23, 2011 | Area/Code Drop7
I WANT TO KNOW HOW TO MAKE INTERNATIONAL CALL USING THE + BOTTON.... AM JUST HAVING PROBLEM WITH THE + BOTTON ON PANASONIC MY KX-TSC11MXB
There isn't a "+" button you need to use. It's just a way that numbers often get written. If you're in the US, you dial international calls by dialling 011, then the country code and telephone number. An international number may be written as +011 49 23456, for instance, but you don't actually dial a "+".
Jun 06, 2011 | Panasonic KX-T7730 Corded Phone
There is a fax tone when dialling our telephone number.
Set your fax to MANUAL MODE. You will have to press START when you know you are getting a fax.
This is the only way it will work without a dedicated fax line.
Nov 30, 2009 | Canon FAX-JX200
International dialling codes
After dialing 011, the 3 digit code for Lithuania is 370. Dialing 011+370+(phone number) should work. Add 2 0's to the370 if a 5 digit couintry code is necessary. Below is a link to help with interational calling. All the best!
Greg
http://www.q7c.com/travel/telephone.htm
Jun 17, 2009 | Office Equipment & Supplies
Nokia 1100 Speed dialling
Press Menu, select Contacts and Speed dials. Select the key you want,
( to ) and press Assign. Select whether you want to assign to call or to
SMS. Select the name you want and press Select.
After the phone number has been assigned to a number key, you can speed dial
the number in the following ways:
• Press the corresponding number key and then press Call, or
• If Speed dialling is set to "on", press and hold the corresponding number key
until the call is started
Nov 30, 2008 | Nokia 1100
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Lands Phones Logo
131 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
