Question about Belkin (F5D7230-4) Router (587009)
We need the key code for our belkin modem
We cant bring up the page 192.168.2.1
  • eecom May 11, 2010
    Hello....192.168.2.1 is the default address for this router; however if nothing happens when you put this in the address bar, try the following.
    If you’re using Windows, go to Start > (Run) and type cmd into the box: click OK. This will bring up a command line window. Type ipconfig into the window, and press return. In the output that you see, the Default Gateway is the router address. Try this in your web browser address bar.
    A couple more tips: Belkin suggests you don’t add http:// to the IP address. Also, if you are a Firefox user, try IE instead.
    If this doesn’t help, please come back to Fixya. Good luck
SOURCE: Help please
change private lan in modem or router and then try again. 168 is being automatically assigned by one of those devices
Posted on Dec 09, 2007
  • 104 Answers
SOURCE: i need my network key
Hello...if you have logged into your router, you can find your network key by going to Wireless > Security on the menu.
If using WPA encryption, your network key is on this page: it will be labelled Pre-Shared Key or PSK according to the manual I have. Hope this helps.
(For info: the network key may also be known as the passphrase, WPA shared key, WEP key, WPA-PSK, authentication key, or security key).
Posted on Jan 26, 2009
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
  • 825 Answers
SOURCE: I have a Huawei EC 168 usb modem from alltel and
inorder to connect to the belkin router you should have an ethernet outlet from the modem...even if it is an usb modem, go ahead and check whether there is an ethernet port...if there is an ethernet port, then connect it to the MODEM port of BELKIN router using an ethernet cable...if no ethernet port is found then it willnot be possible to connect to the belkin router...
because belkin router has got only ethernet port for getting connected to the ISP...
pls rate me if its useful...
Posted on Apr 04, 2010
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
I have a belkin router but i cant find the security code for it to use it on a different computer
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Error code 051099-1
This seems to be a problem with your wireless router. Check to make sure you put in the proper WEP/WPA Security Code. If you aren't sure what I'm talking about...
Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Jan 01, 2011 | Nintendo DSi Blue Console
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
    This is how you reset your router.....
    Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
    How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    I need a key identification number for my laptop to connect to my Belkin wireless router.
    you need to hard wire the wireless mondem to your PC then on the IE page in the header type 192.168.2.1, this will bring you to the belkin main menu. then you can manually ste up modem!
    Sep 23, 2010 | Computers & Internet
    When am using me wireless belkin router the modem and internet icons on my router, the lights turn orenge. why is this because i cant connect to the internet?
    Make sure that your computer is able to go online directly through the modem.
    If your computer is able to go online through the modem, that means the modem is working fine.
    You will need to connect the computer to the router and the modem to the router.
    open the set up page of the router and change the settings of the router according to the ISP.
    Click Here for more information about the routers and network
    Apr 28, 2010 | Belkin (F5D5231-4) Router
    Internet Explorer cant bring up web page when the wireless router is hooked up. It will when the computer is hooked up directly. The computer says that is connected to the wireless router but IE still cant...
    MAke sure that your computer is able to go online through the modem.
    Then you need to connect the computer to the router ad the modem to the router.
    Click Here for step by step by instructions
    Jan 14, 2010 | NetGear RangeMax WPN824 Router
    Cant connect my belkin router to my modem / computer
    If you connect the computer directly to the modem, does it work?
    If that works then the modem is working.
    Now connect the computer to the router and the modem to the router.
    You will need to open the set up page of the router to check the settings of the router.
    You can set up the router without the CD also.
    It is very easy.
    Click Here for step by step instructions about how to set up the router
    Dec 17, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    2 other computers connected to main, signal strength very poor
    oK
    at the address bar type 192.168.1.254
    should bring a 2 wire page
    go to homenetworking
    then advanced settings
    will ask u for ur modem code
    if u dont remember it click forgot will give u hint if u still dont know click still cant remember password
    will ask u for a system key its in brackets on ur modem
    10 digits will prompt to make new one
    then go back to homenetworking at top of page
    advanced setttings and then at the very bottom you can boost it up GOOD LUCK
    rate my service please
    , JULY
    Apr 11, 2009 | 2wire Computers & Internet
    Belkin (F5D7230-4) Router (587009) Logo
    822 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
