Kidde Nighthawk Combo Gas/co Detector Logo
Posted on Nov 10, 2012
My Kidde Carbon monoxide beeps every 30 seconds and is showing L6 with a flash of 0? It is brand new. What does this mean?
Anonymous
Level 1:
  • Contributor 7 Answers
  • Posted on Nov 10, 2012
Anonymous
Contributor
Level 1:
Answers
7
Questions
Helped
42458
Points
50
L6 is actually "Lb", which is a low battery warning. If the 9V battery is missing, or if the battery's power is low, an "Lb" message will display, which blink's alternately with the current CO reading, while chirping. If this happens, you need to replace the battery.
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Sep 28, 2009
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Anonymous
  • 3 Answers
  • Posted on Dec 25, 2008
SOURCE: what does an err code E03 mean?
Correct. Intermittent beeping is a sign of "component failure". Time for a new one.
Anonymous
  • 36 Answers
SOURCE: KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Anonymous
  • 90 Answers
  • Posted on Apr 23, 2010
SOURCE: My Kidde carbon monoxide alarm beeps once every 35
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Anonymous
  • 48 Answers
  • Posted on Jul 27, 2010
SOURCE: My nighthawk Kidde carbon monoxide detector keeps
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
1helpful
My CO alarm is beeping and the LED display says L6. What does that mean and what do I do?
If the alarm chirps every 60 seconds and the red LED flashes with "Lb" this indicates Low Battery.....replace battery as soon as possible!
5helpful
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
4helpful
Our kidde battery operated Carbon Monoxide detector is beeping and goes off every 30 seconds. I changed batteries, but it is still beeping. Does that mean there is CO2 or does the unit need to be replaced.
Relocate it to an area of fresh air - outside will work.. Does it still beep?
If yes, recover the new battery and toss the unit.
Do you have it located in a steamy damp area? Laundry room, bath room etc.. That will cause it to malfunction too..
17helpful
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
11helpful
3answers
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
16helpful
3answers
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Top Kidde Home Security Experts
 Mikey
Mikey
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
