ARE THERE CERTAIN FORMATS FOR SONGS WITH THIS PLAYER?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
SOURCE: Won't play certain songs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
SOURCE: I HAVE DOWNLOWDED SONGS BUT A LOT OF SONGS WONT COPY TO MP3
Okay, fist, you need to make sure the player is good (boots up, goes to menu, etc.). next, you need to put all of the songs into media player, then SYNCH them to the player. If you can't do that, try putting all of the songs into a folder called "music" and then put them into a subfolder called "albums." it should work shortly afterwards.
SOURCE: my cd player on my computer is broke. where may I
Direct link to the driver CD download for the SMPK4083:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4083_DRIVER.ZIP
Download for the manual in pdf format:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK4083_EN.PDF
SOURCE: I need to find or download the software for an Mp3
U could access the Net go to their website find the model and possible download what U need.
SOURCE: Hello, I have an Emerson 2GB MP3 player and would
Hi
I have experienced before when my cousins MP3 is corrupted A
All song cannot be played because of some faulty songs or files. What I did is I connected it to my laptop using a USB cable and then transfer all the songs files & the picture files from MP3 to Computer. Then I deleted all these songs and pictures in MP3 player.
Then I started playing song and opening picture file each file into my computer to see which on is corrupted (that cause your MP3 faulty). If faulty, delete it. Once you all check the song and it is playing in your computer and pictures can be open to your computer. It means all these files are working good. Make one sample song transfer to your MP3 player and play it in your MP3. Once it played, you can start transferring all files.
Regards
Hi Avis Edwards...
Your MP3 player requires the following:
Music requires.....MP3 (8kbps ~ 320kbps), or
.WMA (5kbps ~ 384kbps)
for music at Constant Bit Rate
Video requires:
.AMV files
For a user manual for your Mp3 player and a FREE video/music converter download it at the following link..(The converter is inside of the download)
Please take time to rate me
Bud
http://data.manualslib.com/pdf/17/1675/167423-sylvania/smpk4083.pdf?554517b4114fb4184bbf967aef135711
I tried the first solution e-mailed to me, nothing happened. My time is limited this has already taken hours of back and forth with the player & computer & I still don't understand. I appreciate the help but can't be limited by time allotted to get this resolved. If time runs out for you I'll re-post. I really don't understand, the download given to me yesterday did absolutely nothing. I'm a working woman & not able to stay glued to my computer. God Bless & I thank you all. I'm not giving up though, I will continue to try till I get it right!
I uninstalled the software, yesterday then reinstalled it today, being sure to use the windows media player it all went well. I am downloading music effortlessly. I also sucessufully downloaded the tools provied for my toolbar and am quite happy with it all. Thank You, FixYa so much. I hope this info also helps someone else. Happily downloading music to my MP3. Thanks Again!
