Question about Activision Call of Duty: World At War for Xbox 360
Can't collect explosives at assault on wana ridge
After leaving the caves there are two satchles to pick up on a bag of supplies. I have tried no end. am I missing something or doing something wrong. Please can you advise ?
Bill.
    Genius:
  • 1,550 Answers
You can get the information from the site below
http://www.mahalo.com/Call_of_Duty_World_at_War_Walkthrough
Posted on Jan 01, 2009
  • 13,433 Answers
Here is a Walkthru for the game
http://guides.ign.com/guides/14222038/page_3.html
find the part where your stuck at from it and im sure you will get your answer.
What is known fact about Kuttumsar Caves?
Yes, Kuttumsar Caves is so beautifull. It is one of the most famous holiday destinations in the area. They are situated in the thick forests of Kanger Valley National Park, near the famous Tirathgarh Waterfalls and remain open from 7am till 7pm.
There is no food, cafe or any shops are accessible near the cave. So carry drinking water and foods. But don't try to enter into the caves carrying bags etc as you have to keep your both hands free.
Jul 23, 2016 | Video Game Consoles & Games
Any advice on homebrewing before I go shopping for supplies?
Make a list before you go shopping and stick to it. Home brew shops are a little bit like Aladdin's cave for home brewers and you can end up coming home with bags of stuff that you don't even need. So write a list and follow it!
Ask lots of questions. Unlike shopping online, the major advantage of going to a home brewer's shop is the option to get advice about products and how to use them. For me, this has been the most valuable aspect of the shopping experience and I think it's worth paying more for supplies from a local shop that gives support, than buying cheaper online.
Once you are familiar with brewing and what you like, you can start to buy in bulk or look out for deals.
Feb 21, 2013 | Crafts & Hobbies
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Sawdust does not collect in bag but remains on wood that is worked on. Have tried to locate problem (probably blockage but have not found cause or remedy)
Best way to clear the vacuum path: remove the sanding belt and collection bag. Use an airhose to blow compressed air through the opening where the bag attaches to blow out anything that may be in the airway. After blowing through the outlet, check around the rear of the drive pulley for any wood that may have to be picked out. Reattach everything and try it again. If it still doesn't work, the vacuum is driven by a fan on the end of the armature. You'll have to take the case apart and check that to see if the fan blades have broken off or the fan has come lose from the armature.
Oct 12, 2010 | Makita 9404 4'' x 24'' Belt Sander
MY AIR BAG LIGHT IS ON ALSO IT SAY AIR BAG PROBLEM ALSO THE ABS LIGHT STAY ON AND ALSO THE BRAKE LIGHT IS ON AND ALSO IT SAY CHECK CHARGE STATUS
hi, what this is basically telling you is that the air bag cylinders are at the end of their optimum charge time so they are on a time delay you will then get the warning you have got untill you get these replaced.
Its just a safety feature telling you to get these parts changed and not drive the car untill you get them changed.
So changing these cylinders will solve your problem but this isnt the kind of job you can do yourself as you are dealing with a pottential explosive and can cause serious harm to you and others around you so please leave this job to a pro plus the light needs resetting witch can only be done by a garage that has been trained in doing air bag work so keep this in mind.
Let me know how you get on or if you need further assistance ok
Dec 17, 2009 | Oldsmobile Aurora Cars & Trucks
Can't find enough explosives to blow up all
You have an infinite amount of TNT in Medal of Honor just find the red blinking box on the objectives and press "E".
Oct 05, 2009 | Video Game Consoles & Games
Stopped to empty bag now won'tstart.
CK TO SE IF YOUR BAG IS ON ALL THE WAY SOUNS LIKE THE SAFTEY SWICH IS NOT PUSHED DOWN ALL THE WAY
Sep 27, 2009 | Garden
Cant find explosive charges on medal of honor european assault game
problem was in the controller itself, when ever the a button was needed for something it would work, but if the a button was needed to be held in for something it would not work. tried a different controller and problem was solved.
Sep 16, 2009 | EA - Electronic Arts Medal of Honor:...
How do I enter cheat codes for call of duty worl at war on playstation 3
Text excerpt found at: http://cheats.ign.com/ob2/068/902/902587.html Cheat: Cheat List Cheats are unlocked not by inserting passwords, but by acquiring the thirty Intel Pieces strewn throughout the game.
The more of them you collect, the more cheats you can access. On the left are the number of Intel Pieces collected, and on the right are the cheats that are unlocked, with an explanation of what each does.
  • 2 - "CoD Noir" Play the game in black and white.
  • 4 - "Photo-Negative" Game colors become inverted.
  • 6 - "Super Contrast" Game's contrast increases.
  • 8 - "Ragtime Warfare" The game feels like an old silent movie.
  • 10 - "Cluster Bombs" One frag grenade thrown equals five in explosion.
  • 15 - "A Bad Year" Enemies explode into tires when shot.
  • 20 - "Slow-Mo Ability" Game plays at 40% normal speed.
  • 30 - "Infinite Ammo" Just what it says.
Unlockable: Arcade Mode To unlock Arcade Mode, beat the game once through on any difficulty level. Arcade Mode itself is split into two options - Full Challenge or Level Challenge - that add extra replayability to the game.
Unlockable: Prestige Mode To unlock Prestige Mode, which is a multiplayer-only mode, you must reach experience level fifty-five. Instead of capping out at level fifty-five, which is the highest level, Prestige Mode allows you to start again from level one. This can be done a total of ten times, giving you ten different icons in in-game lobbies to show your extreme achievement.
Unlockable: New Mission To play an all-new mission, which is an extra mission after the main quest is completed, beat the game and view the ending credits thereafter. After they've run their course, you will then be given the opportunity to play one last single player mission before all is said and done.
Unlockable: Golden Weapons To unlock the following "Golden" weapons, fulfill the requirement listed.
  • AK-47 - Complete all Assault Rifle challenges
  • Desert Eagle - Attain Level 55
  • Dragonuv - Complete all Sniper Rifle challenges
  • M1014 - Complete all Shotgun challenges
  • M60 - Complete all LMG challenges
  • Mini-Uzi - Complete all SMG challenges
Unlockable: Multiplayer Weapons To unlock the following weapons in multiplayer mode, reach the numbered rank listed.
  • Assault Rifle (G3) - Rank 25
  • Assault Rifle (G36C) - Rank 37
  • Assault Rifle (M14) - Rank 46
  • Assault Rifle (M4) - Rank 10
  • Assault Rifle (MP44) - Rank 52
  • LMG (M60E4) - Rank 19
  • Pistol (Desert Eagle) - Rank 43
  • Pistol (Golden Desert Eagle) - Rank 55
  • Pistol (M1911) - Rank 16
  • Shotgun (M1014) - Rank 31
  • SMG (AK-74U) - Rank 28
  • SMG (Mini Uzi) - Rank 13
  • SMG (P90) - Rank 40
  • Sniper Rifle (Barret) - Rank 49
  • Sniper Rifle (Dragunov) - Rank 22
  • Sniper Rifle (M40) - Rank 04
  • Sniper Rifle (R700) - Rank 34
Hint: Intel Pieces Below is the level distribution list for Intel Pieces, which are enemy laptops full of information strewn throughout the game. There are thirty of them total. The left column is the level in question, while the right column is how many Intel Pieces can be found on that level. Levels with no Intel Pieces are excluded completely.
  • Level 2 - 2
  • Level 4 - 2
  • Level 5 - 3
  • Level 6 - 2
  • Level 7 - 2
  • Level 9 - 3
  • Level 10 - 2
  • Level 12 - 2
  • Level 13 - 3
  • Level 14 - 2
  • Level 16 - 2
  • Level 17 - 1
  • Level 18 - 2
  • Level 19 - 2
If the information was helpful to you, please give me a rating.
Thanks.
OpenSource13
Apr 18, 2009 | Sony PlayStation® 3 (60 GB) Console
Activision Call of Duty: World At War  for Xbox 360 Logo
175 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
