Question about X-Micro Technology XWL-11g Router (xwl11grag)
Securing wireless connection
PLEASE HELP!
I have a 11g ADSL 2/2+ router and have no clue as to how to make a secure connection to my remote laptop - eg WPA. I know little about computers, and find the advice posted on various sites incomprehensible. Can someone please give me basic steps to take so even I could do it?
Best wishes
Tel
  • terryelston Jan 02, 2009
    Fantastic! Thanks eecom. Your detailed instructions worked perfectly, even for a duffer like me. You should write a book!
    Great site.
    Best wishes,
    Tel
  • 104 Answers
Hi, I will lend a hand if I can. The fact is, a lot of security advice IS incomprehensible!
I'll try and set it out here, but if anything is not clear, please check back! Also bear with me if I tell you something you already know.
There are four basic steps to set up wireless security, which are the same for most routers:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
This is enough to secure the connection, though you can take further steps when you are up and running.
Here are the details:
1) Login to your router.
Type the router address in the address bar of a web browser. For this router, it is http://192.168.1.1
You should see a popup box. If you have not changed the password, enter username: admin and password: admin
This should bring up the configuration screen/user interface.
2) Change the router password.
If you haven’t set a password, this is a good place to start. Go to LAN setting >Password. Set new admin and username passwords and click 'Apply'.
Ensure this password is not easy to guess, or someone could log into your router and view/change all your settings. It's also a good idea to write this info on a label and stick it on your router.
3) Change the SSID (router name):
Go to Wireless > Basic, and change the SSID from ‘default’ to anything you like –as long as you can remember it. It is case sensitive, and you can usually use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘Apply’ when finished.
4) Enable encryption
Go to Wireless > Authentication.. Select WPA-PSK - strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start off. You might also need to select Shared Key on this menu option – I’m not familiar with this router so bear with me.
You may see one or more new options pop up. I would start by leaving most settings at the default. However, under Pre-Shared Key/Network Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, passphrase, authentication key). Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck...
Posted on Jan 01, 2009
  • eecom Jan 01, 2009
    PS: Important Note! Use a wired connection to your router when setting up security.
  • eecom Jan 02, 2009
    Great news! Many thanks for your feedback and kind comments - made my day.
Cannot get my new laptop to use my wireless connection to my adsl router- wireless g old laptop using xp no problem
For connecting new laptop using windows 7
Goto Control panel-Network and Internet--Click connect to a network on left side of pane--It should show all the wireless networks including your adsl router--Click connect it would ask for security key-Enter your security key for router-You should be able to connect.
If unable to find wireless network of router then try following steps.
> Turn off laptop
>Turn off router and modem (Disconnect power cable)
>Power on router first then laptop
>Then follow first method.
Thankyou
Sep 09, 2010 | Computers & Internet
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Wireless Internet through 2Wire router not working
First of all change your router to WPA rather than WEP. WEP is easily cracked now and is not secure. That might be what your laptop is looking at.
Secondly, update the wireless drivers to the current version from the website.
Make sure your router is broadcasting on 'auto' (802.11a/b/g, and N if supported), It ay be broadcasting only on, say 11g and your laptop doesn't support it. Updating the wireless drivers may also fix this.
Jun 23, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Automatic restart of the router
try checking ur modem button or reinstall windows .if problem presists then contact me at afzaalafridi@rocketmail.com
Apr 30, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Wireless connections
Please you write more detail to problem.
Thank you.
Mar 27, 2008 | Computers & Internet
Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
CONNECTING TO A REMOTE COMPUTER
YOu probably have to open up a port on the router. COntact your IT person at your office and ask them which port has to be opened.
Sep 25, 2007 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Computers & Internet Logo
131 people viewed this question
Top X-Micro Technology Computers & Internet Experts
David Payne
David Payne
Are you a X-Micro Technology Computer and Internet Expert? Answer questions, earn points and help others
