Question about Sony RDR-HX715 DVD Recorder
Sony rdr-hx715- recovery error
Display cycles between "recovery" and "welcome" nonstop.Unplugging unit (for hours) did not resolve problem.Holding power button for 10+ seconds did not resolve problem.
  • Anonymous Feb 19, 2009
    same
  • Rich Wallings Apr 09, 2009
    Continually cycles through "welcome" and "recovery".
Sony model RXR-HX715. No power only fan is working
check for failure in the power supply, you must need a trouble shooting to check weather the power supply has enough output voltage.
Sep 27, 2012 | Televison & Video
My dvd recorder model no dmr - es15 has troubleshooting with u61. where can i get it fixed
The u61 code is a common code on your unit. It signifies an issue with the DVD controller board. The problem is that it will probably cost more to fix the issue than the player is worth. Some techs had luck with dis-assembling the unit and resetting the optical block. If you have the tools and experience you can take the unit apart, disconnect all of the cables and move the optical block back. The error message is defined as the unit either suffering a power outage or being unplugged while it was on. The unit then tries to run it's own recovery program. More often than not the unit will make some noises, then display a message stating the recovery did not work, and advising you to take the unit to your local Panasonic repair center. Some owners had luck with unplugging the unit for a couple of hours, then plugging it back in and switching it back on.
In closing, if the unit displays the message that it did not recover you can then try and unplug for 2 hours. IF that doesn't work then dis-assemble and move the optical block. Failing that pay for a repair.
These steps should allow you to resolve your issue. If you do have further problems please don't hesitate to let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 24, 2011 | Panasonic Televison & Video
Sony dvd recorder will not open
Well while the unit is on and the Welcome is frozen push and hold in the power on button for about 15 seconds or so until the power goes off. Then release the power button. The unit will go on and the Welcome will eventually blink and the unit will eventually cycle into power off with just the clock showing. Then unplug the power and wait, unplugged for a few days to let the memory capacitor discharge..... If further you have the same problem then you need to repair it....... Please post comments for further help or information...........
Good Luck!!
Mar 27, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony RDR-GX220 DVD Recorder is not going past WELCOME
This is not a solution but was told by repairers that an ic has gone bad.
I resolved the problem for a while when I removed internal cable and some how got it working.It worked as long as it was powered up. Had a power failure and now battle to resolve the problem. Suspect that it can be a low voltage out of the regulator ic. The mystery was that when I got it working it worked perfectly. The firmware is also doing a power test and I think this is failing and thats why it is display welcome.
Feb 27, 2009 | Sony RDR-GX220 DVD Recorder
Sony dvd recorder as hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Nov 11, 2008 | Sony Televison & Video
My sony hd dvd recorder RDR-HXD 760 wont turn on or off, it just sits half way and says welcome, have tried holding on/off button down which does work for a bit the it comes back on by itself and goes back...
I had the same problem, my recorder was past it's warranty though. So I opened the case (4 screws on sides & 3 [silver] screws on rear) then unsecured the HDD (4 screws with rubber grommets and 1 screw with thin metal flange) I then disconnected the data and power cable (as illustrated on HDD) powered the whole unit up and got nothing (obviously) reconnected the HDD and plugged the unit in. It powered up and then turned itself off. I then turned it on using the power button and voila, it worked perfectly! All HDD stored videos were still there too! The unit even held the same time.
May 22, 2008 | Televison & Video
Hdd error
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Televison & Video Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
