Question about Apex Digital AT1308 13" TV
Cable channel problems
I cannot pick my classic cable channels. I can get the basic channels. Do I need a box for the rest?
  • 67 Answers
SOURCE: Question regarding my Apex PF2720 TV: One channel
check your close captioning settings make sure they are off you probably are accessing an unused cc chanel
Posted on Apr 14, 2009
0 characters
1 Points
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Standard (CRT) Televisions
Hi...juz wanna know wat wud be d possible solution
You don't say whether you use an antenna or cable company. If you use an outdoor antenna then you'll need to get a converter box to get stations now that everything is digital. If you're on a cable system and you have basic cable(no box) then you need to get in touch with the cable company.
Oct 01, 2014 | Standard (CRT) Televisions
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Standard (CRT) Televisions
Won't pick up cable channels
Do you have a cable box from a service provider? If so you may have to take the cable box back in and exchange it.
Oct 01, 2009 | Standard (CRT) Televisions
With a cable box connected to tv only 1-21 are comming in rest of
set box and tv both to chanel 3 reboot box by unplugging plug back in then do channel scan for digital channels see if that helps
Mar 20, 2009 | RCA F32650 32" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
Cant use all cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Jun 08, 2008 | Proscan PS32500 32" TV
Apex Digital AT1308 13" TV Logo
21 people viewed this question
Top Apex Digital Standard (CRT) Televisions Experts
Jaime Hernandez
andy williard
andy williard
Are you an Apex Digital Standard (CRT) Television Expert? Answer questions, earn points and help others
