Question about Garden
Broken clutch-homelite 240-ut10647-how is the clutch removed ?
How do you keep the shaft from turning if the clutch unscrews?
  • 211 Answers
Hi
You can block the piston in the cilinder with a starter rope with manny nods entered in the sparkplug hole.
best regards savumihai71
Posted on Jan 01, 2009
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Homelite weedeater not spinning
there is a cable that runs thru to the shaft take it apart at the shaft bottom and see if it is broken or unattached.
May 15, 2014 | Homelite Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Trying to remove a clutch rotor assembly on a craftsman trimmer and not sure how to remove it. looks like it unscrews from the shaft
It does unscrew from the shaft. The Torx screw holding it is hidden and doesn't come out of the housing once it is loosened. It is screwed into the end of the shaft. You will have to keep the engine from turning to loosen it. Pull spark plug out and move piston to bottom of stroke. Put some nice, soft, clean rope in the cylinder and let the piston compress it when you turn the Torx screw in the clutch rotor housing.
Jun 30, 2010 | Craftsman 25cc Gas Line Trimmer
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Housing removal outside the Homelite clutch
You must first remove the rear housing, then the shaft to access the clutch area.
May 26, 2009 | Homelite Garden
Replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do I change to clutch on this blender. The outside of the clutch broke off leaving just the screw head on the blender, when I turn to unscrew it, the entire piece just spins, any suggestions.
You can probably use a Vise-grip pliers to clamp down on the brass insert and unscrew it. Not only is it on very hard, but it is also threaded reverse of a normal screw. This is so it does not come undone in normal operation.
You have to turn it counter-clockwise to unscrew it (a regular screw turns clockwise).
I had to clamp the motor shaft real tight with a bench vise to be able to remove the clutch. Hope this helps.
-Vince
Aug 14, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
