For some time if I turned off the tv, the sound would come on but not the picture, eventually the picture would return. Today it has not returned after being on for a few hours.
  • 4 more comments
  • vberg Jan 01, 2009
    My television is a Zenith 27" HDTV approx 5 years old, not lcd.
    model C27V22
    No, I don't run through a sound system.
    Sorry I don't know what a psu is or what you mean by "a con of cheapish looking design". What connections are you speaking of?
    Thank you.
    No, the screen is black and not grey like when in standby mode. Thanks will check all the connections.
    Rechecked all connections to make sure all tight and they appear to be so. I guess will have to call a repair company. Thank you
    Problem Solver:
  • 11 Answers
I need to jknow if you have a anolog tv or lcd tv. reply and i will help ya :-)
Posted on Jan 01, 2009
  • 3 more comments
  • aidan wilson Jan 01, 2009
    thxs that helps me
    i am not to sure but i am fairly certain nit might be a psu problem. apperently they have a con of cheapish looking design and the psu. also scheck your connections give them a little swirl inb the socket it might help. if not take it into a techician and let him look at. i find it odd though to be hearing sound and no picture. do you run your sound the a sound system at all?
    hmmm, do youi get like a glow on your screen even though it is black canyou see like a glow in thye screen.
    ok a psu is a power supply unit that converts power down to a certain level for the tv and its componets. and a con meaning pro's and cons of a product meaning good and bad and the connections i am talking about are the ones that you have connected for your tv dvd player ect..
    see if you can see a glow or a different colour on the blacvk when you turn on the tv
Tv has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Televison & Video
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Panasonic TV without picture
If the sound stays on try just going up and giving it a "whack" on the side, a pretty good one. If the picture springs back to life it is likely a poor solder joint.
Those sets and many others are prone to cold solder around the vertical IC due to the heating/cooling cycles and high temperatures inside a TV. If you hit it and you get a picture back it likely just needs to be re-soldered.
May 23, 2010 | Televison & Video
Problems with the picture
If set is new one and w/guarantee, apply this returning for new one
May 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
LCD TV Problem
Replace Lamp in TV and lamp replacement procedure would be written in Instruction Manual of TV.
Always buy Sony Original Lamp for smooth picture result and avoid aftermarket/ cheap lamps.
Let me know exact model number of TV if you need more help.
Apr 22, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Toshiba 37AV500U randomly going black (almost sounding stuck)
my parents have an older toshiba and the processor went bad on it there tv also made wierd noises and blacked out. i suggest calling toshiba and see if they will send a tech out to look at the tv. Most of your flat screen tvs basically are generic computers
Jan 14, 2009 | Toshiba 37AV500U 37 in. LCD TV
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
