Question about LG 24 in. LDF 7811 Built-in Dishwasher
Dishwasher door drops down with no spring action
  • parcham Feb 08, 2008
    I need to know how the sprin & lanyard are meant to be attached to the dishwasher body.
    Rgds
    Mike
    parcham2007@gmail.com
  • Anonymous Aug 09, 2008
    Kenmore elite door now very heavy--assume that a spring is broken inside
New rope on one spring fixed it
Posted on May 21, 2007
How do I fix my new Miele dishwasher door springs?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number
Jul 30, 2014 | Miele Dishwashers
I have a dishlex 300 and when i open the door it just drops down could this be something with the spring or hinges in the door
tHE DOOR SPRINGS ARE BROKEN. IF YOU HAVE DROPPED THE DOOR TOO MANY TIMES THE HINGES MIGHT BE BENT TOO. yOU WILL PROBABLY NEED HINGES AND SPRINGS....A bit of a job for a novice....like my capitals sorry about that.......
Mar 01, 2011 | Dishwashers
Appears that door "helper spring" or whatever
To understand how the door sits on the hinge and the spring location you need to see this diagram. See item 18.
Jan 06, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Door Drops open
You could have a spring (on both sides) in left or right side of washer "unhooked or broken" You need to open up and check. Normally you open up by 1) Top 2) Back 3) Sides and different washers have screws that need to be taken out. Some springs have a combination of spring and nylon string that just hooks in. This is quite easy to fix with a screwdriver and common sence ....
Apr 21, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Door opens all the way down does not stop
The door is very simple as you already know. The only adjustment is with the springs. If they are in place and the door still drops too low (and probably very quickly stopping with a jar) then the springs are over stretched. This does happen over time.
Take one off and go to a hardware store. Look for ones slightly shorter to replace. Springs are springs so if they fit you are good to go. Or go to a parts shop and purchase replacement parts.
Please rate if this helps you.
Mar 09, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Door drops -- no spring action
there are two nylon ropes that hook the door hinges to the door springs on the left and right side of the dishwasher.usually with time of rope breaks and the door stars to fall down.to fix this pull the unit out and look for the broken rope on both sides of unit at the botom.the new ropes comes in a kit and are abt $15.00.it contains two ropes and new wheel assly.u dont realyy have 2 chge wheels unless they are broken.but chg both ropes.to get rid of that squeeky noise aplly some bearing grease on the rollers over which the rope slides.that will take care of it.
Aug 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Door Problem
There are set springs for the adjustment of the doors on the Bosch dishwashers. they are colour coded for different applications. They are accessed by laying the machine on its back and pulling the springs out of the base. first you will need to check that the nylon lines which attach the springs to the lower part of the door mechanisms are in place and this can also be done while the machine is on its back. or by first removing the side panels to access the door hinge mechanisms. If you have a custom cabinet panel on your machine it may be too heavy for the springs and new springs will have to be installed.
Jan 10, 2007 | Bosch 24 in. SGS43C12 Classixx...
LG 24 in. LDF 7811 Built-in Dishwasher Logo
258 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
