Question about HP Pavilion dv6000z Notebook
Hi,? my machine has an error of loding operating system it's hp 530,it brings this informationn (no hard drive were found ,so it is not detectiting any hard dirve installed.
  • john vecchione May 11, 2010
    check bios far a harddrive what key do you hit when it boots up to go to bios screen ? see if the h d is seated properly do you hear it spinning? does it make a grinding noise ? is it making any noise?
    Scholar:
  • 51 Answers
The most likely explanation is that your hard drive has failed. You can try removing and reseating it. Failing that, borrow one for testing or buy a new one. As a last resort, try putting the hard drive ( or even the whole laptop ) in the refrigerator overnight. Really! :) If this restores operation even temporarily you definitely have a bad hard drive.
Posted on Jan 01, 2009
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
Nov 20, 2010 | HP 530 Notebook PC
After powering on the following message appears: Non-system disk or disk error replace and trike any key when ready. Trying to press F10 or F9 when powering on doesn not give any result. Does it mean that...
First, check if you have any usb memory keys or other removable media in your system. That error used to show up when you'd leave a non-bootable floppy in your pc. If you don't have anything in your system other than your hard drive- listen. If you are hearing clicking, grinding noises- then yes, your hard drive has mechanically failed. If you don't- then the chances the drive is about to fail since the boot sector was corrupted. Try to make certain the drive is seated correctly in your system- if that doesn't help- you will need to contact the technical support for your system to get a replacement hard drive if your system is in warranty- or you can purchase one, and replace it yourself.
Oct 01, 2010 | HP 530 Notebook PC
When i turn on my e system 4213 laptop. keeps coming up with error message operating system not found. please help
Hi make sure you have no usb pen drives, floppy disks, or cdroms inserted then switch on the machine. If you still get the same error then your hard disk drive has malfunctioned or corrupted. If you have a restore cd or DVD insert this and restart the machine you may get an error message stating your hard disk drive is not found if it has malfunctioned.
Sep 10, 2009 | Acer Computers & Internet
Hp 530 Notebook Recovery Disk errors, cannot start now. Error 1005 File:Windowssystem32winload.exe Status: 0xc00000f Info: The selected entry could not be loaded because the application is missing or...
If you trying to recover your pc from a recpvery partition on the hard drive, somewhere the recovery partions has had the file you need to process your request is missing. If you are using the disk that came with your system, you will need to perform a fresh install with formating your hard drive.
Aug 18, 2009 | HP 530 Notebook
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
Added a new hard drive to my desktop compaq presario sr1620nx and trying to install my operating system and its says no operating system found or corrupt partition and when i hit r to recover its brings me...
You can't transfer the operating system. You have to reinstall it on the new hard drive. Most of the time the disks that come with a computer are just restore disks. Without the restore partition that comes on the hard drive that came with the computer, those disks are usually useless. Or if you want, you can keep both hard drives, and just setup the jumper settings on the hard drives so that the old hard drive is the primary, and the new one is the secondary. Then you will still have the operating system and you will use the new hard drive for storage.
Apr 21, 2009 | HP Compaq Presario SR1620NX...
Error saving operating sysm on hard drive
Sound like the had drive is going out.You should consider replaceing it.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
How to install xp on hp 530
You can try to change in bios show HD as ide native or something like that. If u install xp it gonna destroy your vista installation.
Jul 16, 2008 | Computers & Internet
Laptop receiving message: No operating system found
That error usually indicates one of two things, your file system is corrupt and the master boot record or partition tables have corrupted.... or, in light of a liquid being spilled, some possibly got into the laptop.
I'm not sure right off the top of my head, but I think the hard drive has an access door on the bottom. Which you can remove a couple screws to remove the cover. I would visually inspect under that cover, and other covers if any while your at it, to check for any signs that liquid got in it.
Oct 22, 2007 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
