Aiwa XD-DV480 DVD Player
Problem for Aiwa XD-DV480 DVD Player
How to unlocked region code
By cikojomo on May 07, 2007
Is any body know how to unlocked the region code for this dvd palyer
Solution #1
posted on May 24, 2008
Somewhat Helpful)
jaffa012001
Rank: Guru
Rating: 90%, 469 votes
XD-DV480 Multi-Region: Converting the player to an alternative region:
  • Supply power to the unit and power on from standby mode via the remote
  • Wait until No Disc is indicated on the fascia
  • Now press Pause followed by 3, 4, 2, 2, 9 and then 2
  • The display should now read CODE
  • Now press 0, 0 for region free or 0 then 1 for region one, 2 for region two, and so on (Note: RCE discs will require specific region set)
If the above modification fails to work then the alternative method below may work:-
  • Connect the DVD player
  • Use the Remote Control to turn power on
  • Wait until No Disc appears
  • Press Pause and type the following code, 8, 9, 2, 6, the display will show "CODE__"
  • Within 5 seconds press 00 for all regions
  • Press Pause and Power
This should work for you.
Was this helpful?
Yes
No
Popular Solutions for Aiwa XD-DV480 DVD Player
Questions and Unsolved Problems for Aiwa XD-DV480 DVD Player
Do you recommend Aiwa XD-DV480 DVD Player?
Answer
Answer
plugged in but no power to unit, no LED
Answer
The C D player won't play.It goes around and stop to play each C D but does not play any of them.
Answer
Looking for a region hack for an Aiwa XD DV-270
Answer
the people at the place bought DVD players said that with a seriers or 0's while the DVD compartment... (More)
Answer
When I turn on he's stay like suspend, don't want open the table, turn on the little screen.. what... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Aiwa XD-DV480 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
