Question about AT&T Blackberry Curve 8300 Smartphone
JVM ERROR 513 - AT&T Blackberry Curve 8300 Smartphone
    Brigadier General:
  • 7,752 Answers
Try this method
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows.
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. JVM ERROR 513 - biggrin.gif
Note: Windows 7 beta is not compatible with these instructions.
1. ...
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Posted on Feb 04, 2010
4 Suggested Answers
SOURCE: blackberry error 513
1. Install the desktop software.
2. Install the handheld software. (If it is a non Vendor software.. exp. T-Mobile. search and delete the "vendor.xml" file.)
3. Pull the battery out of your device.
4. With the battery out connect the device to the computer.
5. Go to Options and select "connection settings"
6. Select USB PIN this may take a few moments since there is no battery in the device. you might even have to select detect device in some rare cases.
7. Select the application loader icon.
8. Select all software you want installed.
9. Proceed to the end portion untill you see the "Finish" button.
10. Very IMPORTANT. do not hit the finish button, instead select the ADVANCED button.
11. Make sure both boxes are checked.
12. Proceed until it asks you if you want to automatically back up and restore. Select DO NOT AUTOMATICALLY BACK UP MY HANDHELD.
13. Once the process starts. take care not to bump out the cord and re-insert the battery. Again on some rare occasions you might have to wait until it finishes saying connect to insert the battery.
Posted on Sep 13, 2008
ipodslinger
  • 688 Answers
SOURCE: i need to fix my Jvm error 513 on my black berry
this error comes from not allowing the Blackberry to complete the installation or update.
Just go into your Desktop manager and application loader and reinstall your Operating System
make sure you check what you want installed.
but before you do anything, remove the battery and replace it in the phone, this will reboot the software.
if it comes up your all good.
if you get the error again then reinstall the blackberry os
her is a link to help if desktop manager doesn't recognize your device.
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB03485&sliceId=SAL_Public&dialogID=40774410&stateId=0%200%2040770705
Good Luck and be VERY Patient with the install let it complete
Posted on Jun 05, 2009
SOURCE: my blackberry has the jvm error 513 how do i fix it have JVM 513
my phone show jvm error how do i fix it
Posted on Jun 17, 2009
I tried to update my blackberry pearl 8130 and i accidently typed something wrong when i put in my password, now it says JVM Error 513 and i don;t know what that means. how can i put it back to normal...
JVM Error 513 mean java virtual machine error ,, 513 mean that it isnt loading.. the blackberry uses java as its operating system.. use the blackberry application to update the phone again this will solve the issue,, if not use restore ,, both options are in the desktop application.. basically just update he phone again :)
Sep 17, 2010 | Computers & Internet
Jvm error 513
You basically have to update the software using Blackberry Desktop Manager. If you didn't back up your settings and contacts, there's a risk you'll lose them.
Feb 03, 2010 | AT&T Blackberry Curve 8300 Smartphone
How to reset blackberry with error message jvm error 513
JVM error its a java errror. try to remove memory card and then reset will solve the problem. may be your memory contain virus. connect your mobile to pc nad scan it with good antivirus.....
Nov 06, 2009 | RIM BlackBerry Pearl 8100
Jvm error 513
Contact your cell phone provider to get the phone unlocked.
Apr 08, 2009 | RIM BlackBerry Pearl 8100
My Blackberry 8330 is sayin JVM Error 513 what do i do ?
my blackberry curve 8300 have a problem because my bb have in a white screen jum error 513 an reset but wen i touch they go to the same screen what i can do my mom is gonna kill me
Apr 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
JVM ERROR 513 BLACKBERRY 8310
JVM 513 indicates all data and application on the device have been deleted. To restore, you need to reinstall the Blackberry handheld software and restore the data from the backup file if you have it on your computer. To reload the software, you will have to connect the device to the computer and run Blackberry desktop manager and then application loader. In case you do not have thse software on your computer, check with your service provider and they will have the software available for free download on their website.
Nov 28, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Error 513 blackberry curve 8310.ayuda por favor
BLACKBERRY 8310 HAS A PROBLEM JVM ERROR 513 RESET HOW CAN I FIX IT
Jul 14, 2008 | AT&T Blackberry Curve 8300 Smartphone
Help
JVM Error 513
Jun 30, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
283 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
