Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Blue Color spots on all pictures
I have a Phillips 60 inch HDTV and it is having color problems. We have tried to adjust the color by placing the blue plus signs on the red ones but we are not able to get the blue plus signs to move on top of the red. We are able to get the green and yellow plus signs to line up but not the blue and red. We have moved the TV on one place in our home to another and a day later we sart having this problem. Do you have any idea what could be wrong and is it to costly to correct it. The TV is only 3 1/2 years old. Any advised would be great. Thanks A Bunch!!!!
Hi I have a colour problem on my Phillip Television 60PL9200D on all of the picture is showing Green
Posted on Dec 23, 2008
    Problem Solver:
  • 5 Answers
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
Posted on Jun 29, 2007
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Philips 60" HDTV
If the blue looks like an aura of light around the picture then it is likely to be a problem with the color wheel, probably it should be replaced.
Try first doing a color auto balancing (magic focus) and see how it goes, probably you will need to replace color wheel.
Oct 14, 2008 | Philips 60PP9202 60" Rear Projection...
Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Bill
Nov 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color; everyone and everything is very orange
contact the store you bought it from. They will help you or refund you
Mar 07, 2010 | Philips Magnavox 9P6034C 60" Rear...
We have a 60 inch philips tv that started to have problem with overexposed color (blue) i thought that i could fix this, i moved the lenses a bit rendomly,that did help a little, but then i touched the...
Thats the screen controls. To adjust it turn the color level down to zero, Then adjust the 3 knobs by balancing them to where the best black and white picture is acheived. Then turn the color level up and that should do it. Just be careful not to turn the settings too low or the CRTs will refuse to light after the set gets turned off. If that happens you will need to turn each adjustment up a little and the CRTs will relight then you will need to adjust it more. If you cannt get a good black and white picture you will need to replace the Coolant in the CRts.
Nov 24, 2009 | Philips 60PP9202 60" Rear Projection...
Picture seems to be losing its sharpness and colors bleed
most likely scenario is that the coolant in the CRTs need replacement very common problem with phillips magnavox TVs, The picture will get hard to focus and the color will lose its intensity. You can get a coolant replacement kit for phillips at the following link under the repair kit category. The kit contains all the coolant needed and a CD with step by step instructions on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Feb 08, 2009 | Philips 55PP9401 55" Rear Projection...
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Feb 02, 2009 | Philips 43PP9202 43" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Sounds like your component cables may have come off its contact point. Check to see if your cables have become loose. Pushing them back in place should take care of that but check at the source output and the TV's input. Red Green Blue, when ever one of these 3 come out of contact the TV will produce a color hue relevant to what color remains in contact, looking faint and discolored. If you do find a loose cable connection, inspect the contact ends and squeeze lightly to restore a snug fit but don't do it to hard or you may damage the prongs.
Oct 22, 2006 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
