Question about Bush Televison & Video
Bush LCD30TV002HD - sound working but no picture
We switched on the TV. The screen flashed briefly but then goes ba\lank and remains that way. The sound works fine. Thought it may have been contrast/brightness related at first but could not find a reset button/function. Any solutions? Thanks.
Arpi
  • 326 Answers
SOURCE: Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Posted on Jun 17, 2007
  • 556 Answers
SOURCE: Panasonic TV - no picture, but sound is ok
it is due to vertical section failure.
  • before you start any work reduce brightness to avoid crt burn.
  • please check some loose contact or loose connector.
  • check supply to vertical section
  • check parts in vertical output section
  • check vertical ic.
  • hope this will help.
  • good luck.
Posted on Oct 17, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
TOM2-TOM2
  • 110 Answers
SOURCE: The picture went from clear to snow, but the sound remained clea
Could be the tuner or voltage going to the turner.
Any diagnostics events will be stored into NVM (non-volatile memory) and is useful for troubleshooting.
The diagnostics page can be accessed by pressing the following buttons on the remote control in sequence:
“DISPLAY’, “5”, “VOL-”, “POWER”.
The numbers on the left indicate how many times the timer LED flashed, which designates the probable cause of
the event.
Posted on May 14, 2009
TV screen is blank but the program is still playing
Check the cables, makes sure all connections are still snug. If your using HDMI, try swapping it out for one you know works. There are a lot of lemons out there.
Feb 24, 2016 | Televison & Video
Bush lcd32tv009hd
Could be a bad connector on the set or a bad cable.
It could also be a bad circuit board. If the connections are good, take it to a repair shop.
Apr 03, 2014 | Televison & Video
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
The picture on my Bush tv goes off after about 10-15 secons but the sound remains on. I have tried to move the aeriel without success.
Try with a DVD player and see if it does the same.or go to pwer saving mode and check settings.Than you.
Sep 12, 2011 | Bush Televison & Video
When switched on the picture briefly apperars
if this is a lcd flat panel the invertors for the backlights have failed
Feb 01, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
I have no sound on DVI
dvi does not support audio extra audio connection required
Jan 07, 2010 | Televison & Video
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
No picture sound only
your lcd tv is most likely not getting enough reception for the visual signal, try switching your tv back to analog signal (not digital) if you can by switching off av on remote, do you get your picture back, if yes thats your problem check your aerial, aerial leads and plugs, also do you have an aerial amplifier plugged into a power point, is it turned on to aplify signal.
Jun 22, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
Televison & Video Logo
65 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
