Central haeting ok but no hot water
I have a honywell Honeywell V4073A-3way valve. The central heating side works fine butwhen I select HW the the pump runs and the boiler fires up but the water does not appear to be flowing to the tank coil. Does this sugest that the valve is faulty. the valve motor runs when there is a change form ch to hw or vici versaJohn S
  • John Schlamp
    John Schlamp Jan 02, 2009
    i have a towel rail that is in parrellel with the hot water tank coil and that gets hot with no problems, The valve motor moves ok when switching between central heating and hot water, Is ther a chance that it may be an air lock?
  • John Schlamp
    John Schlamp Jan 04, 2009
    have solved the problem. It was the mechanics between the motor and thw valve shaft jamming up. flush out with WD40. It now works a treat.
  • 334 Answers
If the valve runs at other times, the valve is OK. you have a relay somewhere that is not sending signal to the valve when in that mode.
Trace down all the relays for that cycle and check voltage going int, coming out, and to see if the coil is enrgised.
Posted on Jan 01, 2009
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
I have honeywell v4073a 22 m valve on my central heating and need to get the head off as the valve appears to be sticking and is not sending hot water to the radiators. How do I remove it to check if it...
If you remove the cover of the valve ,you should see some screws that hold the motor head to the valve. you can loosen these screw and the head will come off of the valve body without leaking fluid. you then can try to pivot the valve stem and see if it is sticking or if the the valve motor needs to be replaced. reverse process to install. hope this helps.
Dec 21, 2010 | Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Water leaking
it sounds like the gland on the valve is leaking unusual in a valve so young but it does happen. is the valve electrical operated or water pressure. you should be able to get a complete diaphram kit with all seals etc .
Nov 16, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
254 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
