Question about Emerson EWC19T4 19 in. TV/VCR/DVD Combo
Dvd tray stuck
It looks like the gears to eject and retract the tray are not working? anyone have any clues, or how to's to take apart the t.v and fix it?
I NEED TO KNOW THE CODES TOSET A UNIVERSAL REMOTE
Posted on Dec 13, 2007
Disney cars TV doesn't eject. The DVD seems to be stuck. Does anyone know how to fix that?
CD loading mechanism fault. Contact any service technician. Sometimes, a broken loading belt might be the reason.
Gopakumar Gopalan Google
Mar 25, 2014 | Disney Televison & Video
DVD tray will not go in
To verify there is nothing stuck in your drive, turn off your computer and try manually pushing the tray in GENTLY and feel if there is something blocking the tray moving. If there is nothing preventing the tray from moving manually push the tray in - start your computer and try it again. Use the eject function in windows explorer and try the retract button again. If teh button will not work try pushing the tray in manually again. Once the tray starts moving in it should automatically retract the rest of the way. If the unit will not retract on it's own by either method then the drive should be replaced.
Jul 29, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Can not eject tray to load DVD disc
the mechanism of your dvd are stucked up lubricate the moving parts and gears by using a small amoun of lubricating oil.to do it manually eject the loader by turning the gears by your hand..
May 17, 2010 | Televison & Video
Disc table does not open or close - stuck open
Hello the unit is out of timing now, it will have to be taken apart and retimed. You have skipped some gear tracks and the unit will not close until the Tray is realigned. Try hitting the eject button so the tray comes all the way out then pull on it gently to see if it realigns it self. When it trys to go back in it is hitting the clamper because the tray has not reached home and the clamper that gasps the disk is closing before it has a chance to return home.
Nov 30, 2009 | Pioneer BDP-95FD Blu-Ray Player
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
DVD Tray in computer not opening
there should be a small hole on the front of the tray that you can push a pin in from and it will eject the tray. if its stuck and you still need to hit it, would be best to use your warranty to get it fixed or take it apart yourself and make sure noting is blocking the tray from opening. you may have to take the tray apart and put it back together to get it to work normally.
Jun 01, 2009 | Samsung Super-WriteMaster SH-S183L Burner
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
The cd door is stuck - i cant open the door or close it, help? Tray does not open when switch is depressed. Green light burns steady.
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Apr 18, 2008 | TDK (DVD+RW47BXS5) Storage Media
Dvd tray wont eject
One way i have found is to (no joke) take the back panel off the TV BECAREFUL THERE IS HAZARDOUS VOLTAGE! Look to see if there is a DVD stuck in it, if so remove it. If this doesnt work let me know, i have other possible solutions
Dec 13, 2007 | Emerson EWC13D4 13 in. TV/DVD Combo
Emerson EWC19T4 19 in. TV/VCR/DVD Combo Logo
291 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
