Lan cable Setting for Switch & PC to PC LAN Connection.
    Problem Solver:
  • 13 Answers
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Posted on Jan 04, 2009
  • 3 Answers
New cable unplaged conect & unplaged
Posted on Feb 04, 2010
2 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: Network
Well if you are asking how it should be crimped, PC to PC regularly, if it is not a smart port LAN then you have to use a cross-over cat 5 cable. but it won't really matter if you have smart ports. for the PC to switch connection, same principle applies, but if they have smart ports, that the type of LAN cables should not matter.
Hope this helps.
Posted on Jan 01, 2009
Mitel 5212 IP: PC output has stopped working, no LAN connection to my laptop?
possible dropped out the LAN driver
good bet if you are using win xp or win 7 OS
Feb 11, 2018 | Mitel 5212 IP Phone
Network cable connection not recognized
Make sure the LAN driver is installed and working.
The LAN cable maybe faulty, try another one.
If the LAN cable is a red one then it most likely a crossover LAN cable. This cable is used to connect two computers together without a LAN hub or router.
Sep 21, 2012 | Dell XPS M1330 Laptop Computer PC...
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
The lan ports do not work but the wireless works fine.
I think that the router is just fine.
The issue could be with the LAN card of your PC of perhaps a faulty cable. So, my advice is to check the cable and lan card of your PC. You may use a different/already working cable and a laptop for diagnosis. Note that status of LAN connection is indicated by the LEDs at the front of router and LAN connection of the PC. If the LED indicates connection, then it could be the configuration issue.
Hope this helps!
Let me know if i could be of any further assistance.
Nov 12, 2010 | Linksys WAG325N Router (WAG325N-AU)
Lan Ethernet connection not working
>>try to uninstall and reinstall the LAN driver under device manager
>>try to check if the ethernet cable will work on the other pc
>>or also switch both ends of the ethernet cable then check if you will be getting connection
>>try also to power cycle router or modem if there's no pc's connected
Apr 07, 2010 | Gateway MT6705 Notebook
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
Lan connection!
is the lan port on the motherboard?
if yes, is the lan port turned on in the BIOS?
Does XP detect the port?
If no, check if BIOS setting is on.
May 17, 2009 | HP Vectra VL400 P3 Skt 370 Motherboard...
Network
Hope this helps.
Jan 01, 2009 | Computers & Internet
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Computers & Internet Logo
620 people viewed this question
David Payne
David Payne
