Network Lan Cable Setting for Switch & PC to PC LAN connection.
    Genius:
  • 1,689 Answers
Well if you are asking how it should be crimped, PC to PC regularly, if it is not a smart port LAN then you have to use a cross-over cat 5 cable. but it won't really matter if you have smart ports. for the PC to switch connection, same principle applies, but if they have smart ports, that the type of LAN cables should not matter.
Hope this helps.
Posted on Jan 01, 2009
ERROR CODE EA21F7
LOTS TO CHECK
Check if the LAN cable has been correctly connected, if the SMTP server is ready for communication, if the network settings
such as sub-net mask setting are correct, or if the E-mail address of the destination is correct.
LAN cable has not been connected, or failed to communicate with
the SMTP server. You tried to transmit the document to an incorrect destination address.
A LAN cable is not connected. Check that the LAN cable is connected correctly. The network of the network multifunction
machine and the PC with the IP address of the destination mismatch.Confirm whether the network settings of the PC and the network settings of the network multi-function machine pose a
network-type problem.The network settings in the PC have
not been set correctly.Check the TCP/IP settings of the PC.
The network board of the PC with the IP address of the destination has failed. Replace the network board or the PC. Power is not being supplied to the HUB. Supply power to the HUB. A cross-type network cable is not being used for Peer-to-Peer connection.
Use a cross-type cable. The network cable is disconnected. Replace the network cable. Network load in the destination PC is
too high. Check whether a mail with large size data is received in the destination PC, or a large file is downloaded from the Web.
There is too much transmission data. If the scan resolution is set high, scan fewer pages. The access is limited by the firewall
(Windows Firewall) of the network connection in the PC.
Consult with the network administrator, and change the firewall (Windows Firewall) settings of the network connection.
Dec 10, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Network cable connection not recognized
Make sure the LAN driver is installed and working.
The LAN cable maybe faulty, try another one.
If the LAN cable is a red one then it most likely a crossover LAN cable. This cable is used to connect two computers together without a LAN hub or router.
Sep 21, 2012 | Dell XPS M1330 Laptop Computer PC...
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Two PCs are connected through LAN for internet. one is working properly. In activity of LAN connection status bytes are not received. sending function is working
It could be the cable that you use. Try to switch the cable and see if the other computer is working correctly now. If still the same computer is not working, than it will be a setting on your computer. You can try to open configuration screen, network settings, and click on your active network. There you can choose whether you have a 'home network', open network or business network. Choose 'home network.
Sep 06, 2011 | Computers & Internet
The on board LAN network is not work, System
1 - simple test: connect the pc to a switch using another piece of cable and look at the led on the switch corresponding to the cable - if it doesn't light up when you plug the cable in the pc then the onboard LAN is fried. Unrepairable, get a new PCI one.
2 - that board has a VIA KM 266 chipset that has only one channel of memory that can be either DDR266 or PC133 SDRAM.
May 03, 2010 | Asrock K7VM2 Motherboard
The internet providers technical person connected the cable and told me that your lan card is faulty so change it. my lan card is inbuilt on motherboard
Unplug your power cable; Take off your casing cover; make sure your hand is dry and clean, install your LAN Card to the right slot (Please refer to your Network Card Manual Book); Power On your PC, Press Delete at boot screen until u login the bios screen, go to the Advanced Tab on the top there, Select [Disable] for Onboard Lan; Then save & exit. You're done well! Congrat!
Dec 01, 2009 | ASUS M2A-VM Motherboard
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
Sir i we are 2 friend connected with LAN hub we want to connect via LAN. i want LAN setup between us
yes for this you both have to set workgroup name same .first connect the LAN cable to lan ports of yours...then in Network setting give manual ip addreess as 192.168.1.1 in one computer and in other as 192.168.1.2 (subnet mask would be same) .then u bath can access each other computer by sharing folder....
but you have to disbale windows firewalll
Dec 09, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
