Question about SanDisk Sansa MP3 Player
SanDisk Sansa Express MP3 player stays at SanDisk logo
When I power on it stands at SanDisk logo for few seconds and goes off. When I connect it to computer, SanDisk logo comes on and goes off for for every few(5) seconds. Not getting charged as well.
I tried doing rest by pressing the middle select button and Vol+ button. Still didn't work.
Some one has suggested me to comemct microSD card and check.
I have tried connecting micro SD card it didnt come up by itself. Then I poweron. Again it stays at SanDisk logo for few secs and goes off. Even if I connect to computer, I could see only SanDisk logo.
Can you please help me???
  • mike595 Jan 08, 2009
    I have the same problem but when I install the firmware it says I need to plug in my device and wait for windows to recognize it. Windows recognizes it but the firmware installation won't continue. If someone could help that would be great!!!
  • 728 Answers
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Posted on Jan 05, 2009
  • Jazz Boyce
    Jazz Boyce Jan 09, 2009
    When you plug in your device, hold the minus button before plugging it in to the computer and while it is in the computer until a message pops up and says something like searching for hardware for you device or something like that.
When i turn on my sansa e260 and show the sandisk logo, it restart showing the logo over and over without going to the main menu, how do i fix it ?
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Nov 03, 2011 | SanDisk Sansa e260 MP3 Player
How do you shut it off
Press the power button for a few seconds until the Sansa logo shows up on the screen. Make sure it's not connected to your computer, the Sansa will not turn off if it's connected.
Sep 17, 2010 | SanDisk Sansa e260 MP3 Player
Sansa express 2GB not working, cant update too..
Try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Mar 02, 2009 | SanDisk Sansa MP3 Player
E250 startup problem
Download the Sansa Recovery Tool, and then repeat the same procedure that you followed above.
Feb 19, 2009 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Express MP3 player stands at Sandisk logo!
You will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Dec 31, 2008 | SanDisk Sansa MP3 Player
SANDISK SANSA PLAYER PROBLEM
my sandisk sansa express just shows the logo then turns off need help
Aug 30, 2008 | SanDisk Sansa MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 only sandisk logo on powerup
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Again, select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
