Question about Hitachi SuperScan Elite 802 21" CRT Monitor
Connecting PC to television
Get picture of PC screen on TV for about 5 seconds then blank and message "Out of Range"
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try the lowest possible Screen Resolution in the PC's Display Properties. You could also try lowering the Screen refresh Rates. This is especially so if the PC connects to the TV using composite (yellow) video out or S-Video. In some video cards/settings, it may be necessary to enable twin/dual view in the display properties.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
Hp 2509m picture stays on for a few seconds then goes to Black
I had the same issue, It actually turned out to be the backlights themselves. An easy way to check this is by shining a bright light on the screen while its on. you should be able to see the picture.
Feb 20, 2012 | HP 2509m 25 in. TV
Problem with setting up PC mode on my LE40S7 LCD TV
hi it shouldnt matter to much its just a guide line just might mean you get a less clearer picture if you was watching say a dvd but your telly should still let you acess this menu have you tried acessing the menu without the laptop plugged into it let me know ok
Feb 11, 2008 | LG 42LC2D 42 in. LCD HDTV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Out of range
Out off range means the resolution coming out of your laptop is too high. Remember it's the res. of your second monitor you'll want to change. I'm thinking it'll be 1024x768 max, but may even by lower. Hope this helps.
Jan 22, 2008 | Bush WS6671 28" TV
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
Jan 09, 2008 | JVC AV-32D305 32" TV
Hitachi SuperScan Elite 802 21" CRT Monitor Logo
214 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
