Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Power supply bad on sony kv-36hs500 cant find part on internet
Some siyes say sony does not make part anymore, any info would be helpful
    Problem Solver:
My standby light is blinking 5 times while tv is on and it takes a long time to come on at times
Posted on Jul 20, 2010
    President:
  • 2,692 Answers
Your model number, support and parts page all come up on the SONY electronics web site below.
http://esupport.sony.com/US/perl/model-accessories.pl?mdl=KV36HS500
Posted on Jan 01, 2009
  • 837 Answers
  • Jay Glendenning
    Jay Glendenning Jan 01, 2009
    And I would appreciate a FixYa if they can ... Thanks, Crayz
Isn't turning on, goes on for a second then light blinks 8 times
That means the EHT has exceeded 33KV and it will shut down.
Probably caused by a faulty/maladjusted power supply. Check the 135Volt rail.
Hope that helps.
Mar 01, 2011 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Kv-36hs500 quit working and red light flashes 10 yrs old
This is an indication that you have a problem on the power supply section or on the load because of the following reasons :
1. Over Voltage - the regulator might be cycling on over voltage due to lack of load.
2. Over Current Protection - excessive load or faulty power supply cycling will
trigger the over current protection circuit.
3. High voltage - there might be an excessive high voltage or some other system detecting an out of regulation condition. However, in this case, there should be some indication that the deflection and HV is attempting to come up - momentary whine, static on the screen, etc.
4. Leaky Capacitor - a dried up main filter capacitor or other filter capacitor in the low voltage power supply that is producing an out-of-regulation condition. A bad filter capacitor on the output of a series regulator may result in excessive/drop of voltage causes your unit not to power up unless isolated.
5. A problem with the microcontroller, relay or its driver, or standby power supply.
This is not DIY and quite technical so I've advice you to look for a qualified technician or send it to repair shop to isolate the problem.
Thanks for using fixya.
Please rate my help.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KV36 HS500 7 BLINK PROBLEM
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that helps.
Nov 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby light blinks you hear the contactor clicking in set, no audio and no video displayed. sony kv-36Hs500 only looking for response if this is free of charge
this symptom is usually caused by a breakdown in power supply circuit or it may also be caused by a breakdown in the horizontal deflection circuits which includes horizontal oscillator, pre drive or drive circuits, horizontal output transformer, horizontal output transistor and high voltage circuits (flyback transformer). pls observe precautions in dealing with this high voltage circuits and if so happen you are not inclined with this kind of work, it is better for you to bring it to a qualified technician to avoid accident. good luck!
Jul 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My tv stays on favorite channel menu and I cant get it to change to video. The remote only powers on the unit and wont change anything or turn off. The menu on the tv wont help. Please help
Sounds like you have a stuck button on the front of the TV or a bad protection diode in the keypad matrix that will need to be looked at by a technician.
Jul 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
this is almost certainly a ht proplem chech ht transistor by removal then turn tv on it should if so replace transistor be carfull high voltage may be still present on capacitors
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
The TV will not come on
The power supply on the tv may have gone bad.
Dec 07, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony WEGA KV-36HS500
you may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
Aug 19, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
207 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
