Question about Freezers
Brandt freezer not working
Fan goes on and of but freezer wont freeze
  • 750 Answers
Welcome to Fixya
My name is Huum,
You said,Brandt freezer not working.
If this means band new unit not working???
Do not repair your self or you will void the warranty in a new unit. Use warranty service under these circumstances.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Jan 01, 2009
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Freezer goes in cycles - some days it freezes fine then other days we wake up and the meat, etc that is in the freezer is no longer frozen. Freezer is on top of refrigersator. Refrigerator is fine
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 07, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Jan 05, 2010 | Freezers
I have a Brandt Apollo frost free fridge freezer which is malfunctioning, it is about four years old. The fridge section is dead whilst he freezer funtions. I noticed also that the interior light had got...
it may be repairable. setting the freezer aside for a moment, check to see if the fans come on when you first plug it in. make sure the vents dont have food debris in front of them. If the fans do not come on, you may be able to simply replace the fan or fans that pull warm air and blow cool air into the fridge. they get there cooling from the same coils and the freezer is working, so must be fans or fan relay
Nov 18, 2009 | Freezers
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Oct 09, 2008 | Beverage-Air 23.1 cu. ft. / 654 liter...
Freezers Logo
379 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
