Question about ASUS P4S800D-X Motherboard
Adding memory to tx pro mainboard
Will not recognize the added simms memory sticks to bring memory to 128
    Novelist:
  • 101 Answers
You do not say what memory you are trying to install.
The ASUS P4S800D motherboard has four memory slots that hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot, so the installed maximum is 4GB.
DDR memory is generally available in 128MB, 256MB, 512MB and 1GB modules. If you already have memory installed, it must be at least 128MB so you cannot add modules to 'bring memory to 128'.
Either you have a different motherboard and posted in the wrong section, your memory calculations are wrong, or you have used older PC-133,PC-100 or PC-66 memory instead of DDR. The last is unlikely as older SDRAM has two notches and won't physically fit into a DDR slot that only has one notch.
Please re-post with the specific motherboard model just to confirm and a list of the memory modules you are trying to use.
Posted on Jan 01, 2009
How to enlarge RAM capacity
You must either buy larger RAM SIMMs that are compatible with your system, or buy more of what you have (if there are more SIMM sockets in your system.
Dec 03, 2015 | Computers & Internet
Beep error 1-3-2 how to resolve it, i have 5 RAM's every RAM have same output or error. please give me the solution
Take out all of the SIMMs. Put one in and power on the PC's
If this errors then take that one out and put another one in. If this errors do the same for the others.
You may also find that removing one of the SIMMs sticks will allow the system to start. As they may have to be added in pairs. ie. You have 2, 4 or 6 installed. But 5 will not work. Check the Dell site to confirm "configuration of Memory".
Jan 11, 2014 | Dell Dimension 8200 PC Desktop
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128...
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 11, 2010 | Gateway Performance 800 PC Desktop
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Memory upgrade not recognized (DFI ns35-sl)
U have to use one stick of 512 or two sticks of 256. Motherboard not likely to recognize sticks installed with different capacities.
Sep 04, 2009 | DFI NS35-SL Motherboard
I want to use both RAM sticks
You may not be able to. the sticks usually have to be added in matching pairs. some older machines may read them mismatched
Aug 19, 2009 | Microsoft Windows XP Professional SP2 Full...
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
ASUS P4S800D-X Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
