Question about Dell 1320c Laser Printer
Will not print. Orange exclamation mark/point on - not flashing
    Genius:
  • 1,689 Answers
You may follow Dell's preventive maintenance on the printer you have, the orange exclamation mark regulatly mean a hault on the printer's operation. The link will show you have to have it cleared and make the printer operational once again.
Dell's preventive maintenance for printers.
Posted on Jan 01, 2009
This link is not working. The device on the question is a Lexmark E332n and not a dell. The problem is about the toner or maintenance kit compatibility.
Posted on Nov 29, 2011
3 Suggested Answers
SOURCE: I have a HP LaserJet 1320n printer and it will not
Possible Solution to your issue!
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state
Posted on Feb 23, 2009
  • 117 Answers
SOURCE: Triangle with exclamation mark is
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Posted on Feb 07, 2011
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
Red exclamation point on verizon set top box
How to reset your Set Top Box to fix common problems FiOS TV Residential...
Resetting your Router and Set-Top Box can resolve a variety of issues such as:
  • Missing Interactive Media Guide (IMG) or On Demand menu
  • Unresponsive Set-Top Box
  • DVR recording problems
If you are having any of these issues, you may need to reset your Router and Set-Top Box. Will resetting my Set-Top Box erase the selections I have programmed into my remote?
No, all settings and selections you've entered such as device codes, favorite channels, and recent On Demand selections are saved and available after resetting your Set-Top Box.
Always reset your Router first and then check to see if that resolves the issue. Resetting your router may be all that is needed.
Important note about your router To avoid problems with your FiOS TV service, make sure your router is plugged in and turned on at all times. Even if you are not currently using the Internet, your router still needs be turned on so that FiOS TV can function properly.
To manually reset your router:
  1. Unplug the power cord to your Router for 15 seconds and then plug it back into the electrical outlet.
  2. Wait 30 seconds and then check to see if this resolves the trouble. If you still have the problem, follow the steps below to reset your Set-Top Box.
To manually reset your Set-Top Box:
  1. Unplug the power cord to your Set-Top Box from the electrical outlet for 15 seconds and then plug it back in.
    Note: Don't confuse the power cord that provides electricity to your Set-Top Box with the coaxial cable that is connected to the back of your Set-Top Box. Unplugging the coaxial cable will not reset your Set-Top Box. Since many issues can occur if your coaxial cable is not securely fastened, now would be a good time to check to ensure all connections are securely connected.
  2. Wait for the time to appear on the front of the Set-Top Box, then power it on.
  3. Wait several minutes while the Interactive Media Guide updates.
  4. Check to see if this resolves the trouble. If you still have the problem, your Set-Top Box may need to be re-initialized. Contact the Fiber Solutions Customer Support for further assistance.
I have to reset my Set-Top Box frequently, is this normal?
No, if you routinely have to reset your Set-Top Box more than three times a week, it is likely there is an issue with your Set-Top Box that needs to be resolved. Contact the Fiber Solutions Customer Support for further assistance.
also you can call for tech support at Dial 1-800-VERIZON (1-800-837-4966)
Oct 05, 2012 | Televison & Video
Orange light with exclamation mark
That symbol is the Low TIre Pressure Warning. It tells you that your tire pressures are low.
Aug 31, 2009 | 2001 Toyota Prius
Orange circle with a flashing exclamation point.
this usually indicates a gearbox fault. take it to a garage and they will plug a laptop into the vehicle and tell you what exactly the fault is.
hope this helps.
Mar 18, 2009 | 2000 Mercury Sable
Lights came on dashboard
I already found the owner manual on the internet. thanks for helping me out.
Jan 29, 2009 | 2000 Volvo S40
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
Flashing orange light with exclamation mark
Just talked to a mate of mine who said its the ASC that has been turned off. I flicked the ASC switch and problem solved.
Dec 09, 2008 | 2002 Mini Cooper
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Dell 1320c Laser Printer Logo
2,654 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
